Almost 100% Complete Led Snap-Shots
Talk about you and your tank/equipment
PostPosted: Mon Aug 27, 2012 6:31 pm
Here are some pictures as requested by Roberto.
First up in my Auto Fan controller that controls the fans for the led heat sinks.
I currently have the fans set on Manual mode and running at 80% Very very quiet fans!!!
Don't mind the temp readings as the probes aren't attached to anything yet!
Also I will be building a Case for the Fan Controller and will be mounted right in the middle of the two smaller heatsinks on top.
here is a full view of the led module ( I still need to run my cable loom and also attached it to my wire loom holder attached to the canopy framing.)
( on the right hand side I have a string of blues turned off as I was re-attaching two optics )
FTS
mind you these pictures are taken with a Droid X2 Cell phone.
Adam
58 Gal
PostPosted: Mon Aug 27, 2012 8:16 pm
Nice stuff :)
Return to You and your tank
