Trouble uploading from wizord
Posted: Sun Sep 16, 2012 3:39 pm
by Gideon1
My controler won't update from wizord. I was given a patch to fix repeat dosing problem and tried to generate and upload codes but keep getting error. Here is what i'm trying to do but i get error on bottom of wizord that I can't copy (don't know where clipbord is) wont copy and paste, the normal way. Hope someone can help me, it's been like 4-hours all that's on in tank is my heater pluged into the wall :|
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port2,21,30,10,0 );
ReefAngel.StandardLights( Port3,10,0,21,30 );
ReefAngel.StandardLights( Port4,10,30,21,30 );
ReefAngel.StandardHeater( Port6,787,815 );
ReefAngel.DosingPumpRepeat( Port7,420,1440,20 );
ReefAngel.DosingPumpRepeat( Port8,425,1440,20 );
Re: Trouble uploading from wizord
Posted: Sun Sep 16, 2012 4:30 pm
Code compiles file here.
It must be the file you are using.
Try the attached one.
Posted: Sun Sep 16, 2012 5:51 pm
by Gideon1
Thanks for getting back with me....but this still is not working...can you log in and see for your self?
Posted: Sun Sep 16, 2012 5:58 pm
sure, pm me the id
Posted: Sun Sep 16, 2012 6:06 pm
For your reference in the future, here is a link that has the shortcut keys for copy and paste:
http://wiki.answers.com/Q/What_are_hot_ ... plications
