Page 1 of 2
"Entry" Level Controllable Pumps?
Posted: Mon Feb 25, 2013 11:26 am
by Paulturner911
Im looking to add more flow to my tank. I dont have a budget for the MP-40 but Ill go with what I can get. I was thinking the JBJ Wavemaker setup? Any ideas?
Re: "Entry" Level Controllable Pumps?
Posted: Mon Feb 25, 2013 2:30 pm
There's nothing cheap that's controllable. The Tunze's may be cheaper, but if you don't have analog dimming module or relay box, then you'll have to fork over cash for that. If you want to use a standard cheap powerhead, you can use the Wavemaker functions which would just be alternating power on two powerheads...
Posted: Mon Feb 25, 2013 2:32 pm
by DrewPalmer04
JBJs work great with the RA wavemaker code FYI
Posted: Mon Feb 25, 2013 6:42 pm
by Paulturner911
I think I'm going with the jbj. Thanks!
Posted: Mon Feb 25, 2013 6:47 pm
by DrewPalmer04
Go with the bigger version. The small ones are only good for 40 or less gallons, I'd say.
Posted: Tue Feb 26, 2013 7:42 am
by Paulturner911
I was going to run teh 500 in my 75 firing from the rear glass to the front...I dont want too much since Im not running them lenghtwise. Thanks for all the input! Im currently trying to figure Inrush current on my (2) MH175 ballasts to decide if I can Pig tail them into one relay plug...To make room for the pumps and run a code to cylce them.
Posted: Tue Feb 26, 2013 7:46 am
by DrewPalmer04
That's risky business. But you might get lucky.
Posted: Tue Feb 26, 2013 8:42 am
Just get a other relay box :)
Posted: Tue Feb 26, 2013 8:54 am
by Paulturner911
Would I also need an expansion relay? Im running the wifi....
Posted: Tue Feb 26, 2013 9:23 am
I would not suggest 2 ballasts in a single port.
You may end up with a dead port :(
No need of an expansion hub if the relay expansion is your only expansion. The wifi attachment is connected in another port.
Posted: Tue Feb 26, 2013 9:28 am
by Paulturner911
Just get the $119 relay expansion or the $89 replacement relay box?
Posted: Tue Feb 26, 2013 11:12 am
by DrewPalmer04
Or use wall timers. Lol. They are just MH after all. On and off. Ya know? Whaaalllaaa two free RA Relay ports.
Posted: Tue Feb 26, 2013 11:20 am
You'd need the expansion not the replacement box to get extra ports :)
Posted: Tue Feb 26, 2013 12:08 pm
by Paulturner911
I COULD use timers...But then they wouldnt go off in Feed Mode. Im thinking about the current applied to the relay. I have also have a Coral Vue(?!?) 3lt MH150 Sunpac ballasts that only has one plug which draws 1.5 amp per ballast(4.5), I currently have on my tank 2 MH175 Advance M57 that draw 2.02 (4.04). NOW that being said, and Im no electrican by any means, wouldnt you think I was in the clear?
Posted: Tue Feb 26, 2013 12:13 pm
Inrush is different than operating current.
If you check the ballast spec, you will see something like 30 or 40A for each ballast.
Sent from my Galaxy S3 using Tapatalk 2
Posted: Tue Feb 26, 2013 12:50 pm
by Paulturner911
Inrush for the ADV M57 @ 120v is 18amps, 2 would be 36amps. What are these relays rated to? I also remember someone saying certain ports were designed for the wave maker function. Is this true that all of the relay ports are not the same?
Posted: Tue Feb 26, 2013 12:55 pm
16A
Yes, port 5 & 6 have dampening components to reduce inductive spike.
Posted: Tue Feb 26, 2013 1:04 pm
by Paulturner911
Ouch! I guess Im not even close then....Im over the capactiy now?!??!
Posted: Tue Feb 26, 2013 8:03 pm
by Paulturner911
OK I moved the MH to 7-8. Ive quickly searched for the 5-6 wavemaker pulse code. Anyone wanna offer it up? I think Im getting to where I could mold it to my application. Im not sure if I want it to turn off when the light are off or not...play it by ear. Thanks a bunch!!
Posted: Wed Feb 27, 2013 8:24 am
by Paulturner911
Is this the code?
ReefAngel.Timer[1].SetInterval(random(15,90));
ReefAngel.Timer[1].Start();
Posted: Wed Feb 27, 2013 9:51 am
What do you want to do?
Posted: Wed Feb 27, 2013 10:06 am
by Paulturner911
rimai wrote:What do you want to do?
I would like 2 powerheads to (port 5-6) to toggle between each other at 30-180 seconds. Maybe this?
// Randomize the Timer
static time_t timer=now()+30;
if (now()>timer)
timer=now()+random(30, 180);
ReefAngel.WavemakerToggle(Port5, Port6, timer);
Would this also go where all of my standard code goes? I dont have code anywhere else that I have added.
Posted: Wed Feb 27, 2013 10:29 am
Try this:
ReefAngel.WavemakerRandom1(Port5,30,180);
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
You can do this with the wizard too :)
Posted: Wed Feb 27, 2013 10:56 am
by Paulturner911
Thanks!! This unit is killer!
Posted: Wed Feb 27, 2013 4:43 pm
by Paulturner911
if ( (hour() >=1) && (hour() <12) )
ReefAngel.Relay.Set(Port4, now()%900<120);
ReefAngel.Relay.Off(Port4);
Just checking if this translated to every 15min dose for 2min?
Posted: Wed Feb 27, 2013 4:58 pm
Yes just keep in mind that it will be 13 minutes after the dose...if you want 15 minutes between the end of the first dose and the start of the second then you'll need to add 2 minutes to the 900...
Posted: Thu Feb 28, 2013 6:56 am
by Paulturner911
I understand. Im still dialing it in a bit. I ran into a cycling issue with the wavemaker and my delay for the powerheads...I just removed the line for the delay and all was well.
A Few Questions
If I want to to run from 10pm to 12pm would my time look like this
((if ( (hour() <=22) && (hour() <12) )?? Was NOT sure about this.
I would also like to maybe make the wavemaker cycle at different intervals at night. Would that look like this...
//10pm-9am Wavemaker 15min-60min Random
if ( (hour() <=22) && (hour() >=9) )
ReefAngel.WavemakerRandom1(Port5,900,3600);
ReefAngel.WavemakerRandom1(Port5,210,900);
ALSO!! Would this be how to do both completely random?
ReefAngel.WavemakerRandom1(Port5);
ReefAngel.WavemakerRandom2(Port6);
Posted: Thu Feb 28, 2013 9:11 am
No... && means AND, so you are asking is time is less than 22 AND less than 12... Well... That doesn't make sense, right?
It should be this:
if (hour()>=22 || hour()<12)
|| means OR
Your code snippet looks good.
Yes, if you use WavemakerRandom1 and WavemakerRandom2, both are going to be completely random.
Posted: Thu Feb 28, 2013 12:38 pm
by Paulturner911
Thats going to take a bit of trial and error.
Could you give a good rule of thumb as to when to use && vs. ||? Is it because Im rolling between am/pm??
It seems that most of my if/then conditionals have &&. Im sure it will make sense I just need to wrap my head around it.
Posted: Thu Feb 28, 2013 12:47 pm
It's basic logic statements...
AND or OR
So take an example a blue ball...
if (ball=blue) && (ball=round) then true
if (ball=blue) && (ball=cube) then false
if (ball=blue) || (ball=yellow) then true
if (ball=blue) || (ball=cube) then true
So AND both sides need to be true for the condition to work...
For OR only one side needs to be true for the conditional needs to be true.
