Custom Water Level Expansion - PNY Edition
Talk about you and your tank/equipment
PostPosted: Mon Dec 30, 2013 9:39 am
Experimenting with a custom water level expansion... First I had the idea of putting several sensors on one board but I changed my mind and miniturized the design instead... Sensor on one side and the other components on the other side. Would be nice if I manage to put the electronics directly on top of the PVC-pipe... ;-)
My custom water level expansion ("RA PNY Edition") on top of a 1 EUR coin...
200 liter reef cube + 1000 liter FOWLR
PostPosted: Mon Dec 30, 2013 9:46 am
Cool :)
Show us the end result when it is all mounted, ok?
PostPosted: Mon Dec 30, 2013 10:54 am
...and inside a 20 mm (0.79 inch) PVC fitting.
PostPosted: Mon Dec 30, 2013 2:13 pm
Cool concept. The only thing is that it's nice to run airline hose to where water is versus wires.. :) But I love the concept of having everything in a PVC cap.
PostPosted: Mon Dec 30, 2013 4:42 pm
Very cool concept. Would love to see how it works out.
PostPosted: Fri Jan 03, 2014 6:14 am
Got the circuits an hour ago... It's just a few (not to small) components on the board so I managed to solder the components with my old hobbyist tools at home...
PostPosted: Fri Jan 03, 2014 9:18 am
Very Nice!!!
Just be careful not to splash water in there when you insert the tube into the water :)
PostPosted: Fri Jan 03, 2014 9:32 am
I'm by far not an electrical component designer like you or Roberto, but would it help to squeeze a layer of silicone onto there when you are done with it and have it working.
Just as a protection against water.
PostPosted: Fri Jan 03, 2014 9:40 am
The best possible solution would be an air stone with a rubber sleeve to make it a perfect fit against the plastic wall.
The sleeve would be soft enough to create a "seal" between two hard surfaces (The airstone and the plastic wall) and the air stone is porous enough to let air pass through to the sensor.
PostPosted: Fri Jan 03, 2014 12:54 pm
I plan to cover or glue something in front of the elektronics...
Return to You and your tank
