bigger tank
Posted: Wed Feb 12, 2014 5:47 am
by riggeek
Looking for some feedback
When I update my tank I will have to add a 3rd led, but must tanks have a brace there. I was thinking about the kessel A360. Any ideas how to deal with this.
I also understand that that light does not turn all the way off with dimming. Is that correct?
Last question
How big of a jebao pump for a 72 inch wide 150 to 200 gallon tank?
Riggeek
Re: bigger tank
Posted: Wed Feb 12, 2014 6:26 am
by ReEfnWrX
Multiple powerheads is always a better option... You get better coverage, and have redundancy if a power head fails..
I would recommend 2 WP40's for 150 or 200... Maybe a 3rd WP25 for the 200 for more coverage?
Re: bigger tank
Posted: Wed Feb 12, 2014 7:16 am
by Sacohen
I agree with ReEfnWrX multiple powerheads is always better than a single and 2 40's should be plenty of movement for that size tank.
Re: bigger tank
Posted: Wed Feb 12, 2014 9:27 am
Maybe I'm overdoing :?
I have 4 powerheads on a 60g.
Re: bigger tank
Posted: Wed Feb 12, 2014 11:10 am
by ReEfnWrX
I hope they are WP10's lol
I just got my WP25 last week, waiting on Jebao cable. I may actually buy 3 more wp25's and take out the wp40... I was dumb founded at the size difference.....
Re: bigger tank
Posted: Wed Feb 12, 2014 11:13 am
by Sacohen
Yeah, there's quite a diffence in size between the pumps.
Re: bigger tank
Posted: Wed Feb 12, 2014 12:08 pm
I saw the size in another post. WP-10 are so tiny. They didn't have them when I bought my samples.
I use 2x WP-25 and 2x MP-10
They are usually WP-25 at 50% and MP-10 at 70% on long pulse 2 minutes duration sync/antisync scheme and for a couple hours a day, when the lights peak, they go into short pulse at 100%.
Except for the 2nd MP-10 that just quit on me a few weeks back.
I was going to buy a new dry side but someone told me to just use a knife to open the seal and change the bearings, but I didn't have time yet.
Re: bigger tank
Posted: Thu Feb 13, 2014 7:34 am
rimai wrote:I saw the size in another post. WP-10 are so tiny. They didn't have them when I bought my samples.
I have an MP-40 dry side that needed the bearings replaced. I screwed up the magnet trying to get them off since I didn't have the right tools. If you do, lmk, I have another drive shaft and the replacement bearings if you have the right stuff to do the swap lmk :) Regardless just be gentle with the magnet on the drive shaft it's not very durable.
Re: bigger tank
Posted: Thu Feb 13, 2014 12:39 pm
by riggeek
Thanks for the info everyone.
Does each pump need it own analog control our will they run of the same pwm output with the adaptor for reefangel?
Re: bigger tank
Posted: Thu Feb 13, 2014 1:31 pm
Technically, you can connect more than one in the same channel, but they would be running the same wave form.
Sent from my Galaxy S3 using Tapatalk
