DIY Skimmate Locker on the Cheap
Talk about you and your tank/equipment
PostPosted: Fri Apr 10, 2015 12:16 pm
I still haven't found a long stem float switch, but I've had one of these for a while, and if I silicone it in well it should do the trick. http://www.amazon.com/gp/product/B0076U ... UTF8&psc=1
PostPosted: Sun Aug 02, 2015 10:04 pm
nice. I've been wanting to put a reservoir signal in my top off water jug forever, but couldn't figure out how to get a long enough float towards the bottom of the reservoir. The silicone seal on the bottom makes me a bit nervous, but a tight seal with a layer of silicone should hold.
-Jon
-Jon
PostPosted: Wed Jun 08, 2016 10:03 am
I have the same container, but I am using it horizontally and punched holes through the white cap.
I will post a picture later.
PostPosted: Thu Jun 16, 2016 3:51 pm
I haven't had to empty a full container yet, but I'm hoping to use the lever on the bottom.
Photo attached.
Sent from my A0001 using Tapatalk
PostPosted: Thu Jun 16, 2016 4:08 pm
Looks great!
Previous
Return to You and your tank
