Page 1 of 2
600Gal + Much More: Final Round
PostPosted: Wed Dec 20, 2017 11:17 am
by tkeracer619
Hey guys, It's been a while since I have been around. I lost my 360gal system during my move and have been focusing on other aspects of my life. Fast forward a few years and here I am again. Instead of packing up and moving on I went all out. The new home was purchased with the intent on going big and I hope not to disappoint.
The display is a 96x48x33H 600Gal commercial glass tank made my Miracles Aquariums. It sits in a recreation room that measures 30x20ft and has a decorative concrete floor. The system itself is a work in progress but is approaching fully operational after 1.5 years of work. The system is plumbed into the basement where it has a dedicated filtration, propagation, and quarantine room. This room consists of...
Tied to main display
100Gal Custom AGE acrylic sump
100Gal 48x48x10" Coral Flat
50Gal 48x20x10" Coral Flat
78" Tall RK2 Commercial Skimmer
Masterflex fed Calcium Reactor
Masterflex dosing pump for Vodka Dosing
Aquamedic Kalk reactor
Vertex Media Reactor
Independent Systems
BTA Propagation System consisting of 6 20Gal All-in-One systems
75Gal QT All-in-One
60Gal QT All-in-One
Support Equipment
Shop Sink - Converts to fragging station
200GPD 9 Stage RODI System
200Gal RODI Storage Tank w/ Closed Loop Dionization
200Gal Saltwater Storage Tank
HRV - Heat Recovery Ventilator - Exchanges house air 3x per day to control humidity but retain heat.
3x 20a Circuits
1x 15a Circuit
Shelving for storage
Storage for 8x boxes of salt
Plans for my ReefAngel
The flexibility of the system is what drew me into the RA world in the first place. I've had the original, the Plus, and will migrate to the Star before this project is complete. I will be monitoring temperature of the room as well as the 11 tanks. ORP, Salinity, PH, and RF for Ecotech Marine Vortechs will be utilized on the 600gal and two coral flats. Lighting and heater control will also be done through the RA.
I would like to mount a tablet to the wall of the room to have the portal displayed. The hope is that I will be able to customize a screen to provide me with critical data from all systems as well as logs to help spot any abnormalities. I am sure other features will be implemented along the way as the system matures.
I'll post some pictures in this thread as time allows. If you want to take a look at the build thread it can be found on RC. http://www.reefcentral.com/forums/showt ... ?t=2578543
Thanks for taking a look, feels good to be back 8-)
Here is the live stream! It should be up between Noon and Midnight MST daily. Best watched in 1080p.
https://www.youtube.com/embed/live_stre ... pIlN7h2Ldw
Re: 600Gal + Much More: Final Round
PostPosted: Wed Dec 20, 2017 1:32 pm
awesome! I haven't read the thread yet but sounds awesome.
everything you want to do should be possible. the tablet app you mentioned could be possible with the Star and Android. an ios tablet app would be limited to the uapp.
PostPosted: Wed Dec 20, 2017 5:48 pm
by tngo
Great thread! I've gone through about half of it and the amount of work that has been put in is amazing. 1600lb tank!! Just thinking about moving a tank that size makes my head spin. Going to definitely read more of the thread when I have time. Lots of helpful pictures and nuggets in there for any one starting a tank of their own.
tim
PostPosted: Thu Dec 21, 2017 9:57 am
by tkeracer619
Thanks guys!
Tngo, it was a beast to move in, one cannot simply lift a 1600lb tank no matter how many friends you bribe with free micro-brew beer and pizza. All hydraulics all the time :P . Thanks for looking through the thread, its starting to come together even if I've had some setbacks.
Binder, that is great news! Android is the way I was hoping to go anyways, so many more options. If you have any suggestions I am all ears. Tis the season for discounted tablets :D.
PostPosted: Thu Dec 21, 2017 12:40 pm
tkeracer619 wrote:Thanks guys!
yea, i need to get back into improving my android app. it's showing its "age". I'm trying to to find some time to work out the details for ideas I have in mind. Life continues to get in the way though but slow and gradual work is being done.
PostPosted: Tue Jan 23, 2018 1:10 am
by tkeracer619
Looks like going beyond 6 temp probes will require a fair amount of coding to the libraries. Until we can work through that I'll use 6 probes to just monitor as well as be a safety to my BTA propagation system. I'll continue to bring modules online.
Currently I am trying to get the 6 probes to display, I was just using the wizard but I suspect it isn't displaying the extra 3 probes due to the screen program. I'll make a custom screen in the next few days. If anyone sees something obvious why it doesn't display please let me know.
So far here is my code... super complex I know :lol:
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port3Bit;
    // Add additional temperature probes
    ReefAngel.AddExtraTempProbes();
    //ReefAngel.Params.Temp[T4_PROBE];
    //ReefAngel.Params.Temp[T5_PROBE];
    //ReefAngel.Params.Temp[T6_PROBE];
    ReefAngel.StandardLights( Port1,11,0,23,30 );
    ReefAngel.StandardHeater( T6_PROBE,Port2,770,800 );
    ReefAngel.StandardLights( Port3,14,0,17,0 );
    ReefAngel.StandardHeater( T5_PROBE,Port4,770,800 );
    ReefAngel.StandardHeater( T4_PROBE,Port5,770,800 );
    ReefAngel.StandardHeater( T3_PROBE,Port6,770,800 );
    ReefAngel.StandardHeater( T2_PROBE,Port7,770,800 );
    ReefAngel.StandardHeater( T1_PROBE,Port8,770,800 );
    ReefAngel.Portal( "tkeracer619" );
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
PostPosted: Wed Sep 26, 2018 9:59 pm
by tkeracer619
Has it really been since January since I posted here? Dang time flys when you're having fun.
I've been running my reefangel offline for a while since I can't get the wifi module to stay connected. No matter what I do it dies around 4-9 days.
Haven't pulled the trigger on the star controller just yet since I haven't really gotten far enough with my current RA+. Time hasn't allowed for me to get much done in that regard, have a baby on the way so things are a little crazy around here.
Anyhow, hope all is well with everyone. Forums seem a bit quiet these days.
PostPosted: Fri Sep 28, 2018 4:27 am
congrats with the baby on the way!
yeah, time does fly when you are having fun. I'm sure you will figure out your issue with the wifi module and all.
PostPosted: Thu Oct 11, 2018 1:53 pm
by tkeracer619
binder wrote:congrats with the baby on the way!
Thanks! We're super excited.
I've almost given up on the wifly module. It's been a royal PITA. Every time I think I've got it, it disconnects and won't reconnect. I have it running with an external antenna even...
I updated the first post with the live stream. Is it possible to embed the video in the forums?
PostPosted: Thu Oct 11, 2018 5:53 pm
Congrats! It's good to see people keeping up on threads like this one :) We have a great little community here and we only spend time on our problems :)
How's your wifi otherwise? I got an Orbi mesh network and it's been fantastic. I have a cloud wifi hub and it drops connection here and there still anyway, but my star's ethernet has been rock solid. I highly recommend the star. It changes some things, but the remote upload is really nice feature.
I'm just now getting back to my tank after a year plus of inactivity. My controller has run most things perfectly without any intervention. My salinity was a bit low, I wish I had a stable salinity probe. Otherwise fixed all my issues up, and waiting for results now. I need to test more. I'm really looking at a lot of these startup alkatronic, reefbot, the neptune one. I really wish these were more accessible. I'm sure prices will come down eventually.
