My new tank - 56G Column
Talk about you and your tank/equipment
PostPosted: Sun Mar 18, 2012 4:34 pm
Here is my new tank, just finished moving everything over from my 10G last night.
"Specs:"
Marineland 56G Column
Koralia 750 & 1050
2x Jager 150watt heaters
HOB Reef Octopus BH90 Skimmer
53lbs custom designed, dry rock from reefrocks.net
Aquaclear 70 as HOB Fuge
2x Ai Nano LED lights
John
ReefAngel and ReefAngel-HD developer
If the RA iOS app has helped please consider a donation
PostPosted: Sun Mar 18, 2012 5:21 pm
Nice. Looking good.
Always so bare when things start up. :)
PostPosted: Sun Mar 18, 2012 5:39 pm
The few frags I had took up all the space in my 10G. It does make the 56 look empty. Will be adding a few more stuff soon once I am sure everything is stable.
John
PostPosted: Sun Mar 18, 2012 8:17 pm
Pretty nice :)
PostPosted: Sun Mar 18, 2012 8:48 pm
That's a nice size tank, are you using RA for this? If so what are you controlling outside of probes and lights?
PostPosted: Mon Mar 19, 2012 4:21 am
Rsmolik wrote:That's a nice size tank, are you using RA for this? If so what are you controlling outside of probes and lights?
Yes the RA+ is "hidden" in the stand. It is controlling:
  • Ai Nanos, currently controlled together, working on separate control
  • Fuge light
  • both heaters
  • Feed mode / Water change mode is configured to turn off all the pumps
  • I created a "flow" feed mode that turns off the skimmer and fuge but leaves the powerheads on.
I was going to use the koralia's on the wavemaker but I think I got a bad 1050 from amazon as it sometimes jams on startup. Going to see if I can exchange it but I will be going with Vortechs soon.
John
PostPosted: Tue Mar 20, 2012 8:27 pm
Vortechs are pricey, but amazing, have you looked into the jbj ocean streams? Mine work well and don't reverse on startup like my older koralias.
Return to You and your tank
