Need Help with Setup
Gideon1
Post by Gideon1 »
Hello all, just got the new RA+ and WiFi, I all totally lost, I am no coder, thought I'd get some help from you guys. I am on OXs mountain lion tried to upload Arduino with codes got error. Relay box is clicking on the RA screen T2 Error and T3 error. Here is the codes load I think:
he following features were automatically added:
Watchdog Timer
Version Menu
Simple Menu
core.a(main.cpp.o): In function `main':
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:5: undefined reference to `setup'
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:15: undefined reference to `loop'
UIDefaults.getUI() failed: no ComponentUI class for: com.l2fprod.common.swing.JTaskPane[,0,0,0x0,invalid,alignmentX=0.0,alignmentY=0.0,border=,flags=0,maximumSize=,minimumSize=,preferredSize=]
java.lang.Error
at javax.swing.UIDefaults.getUIError(UIDefaults.java:712)
at javax.swing.MultiUIDefaults.getUIError(MultiUIDefaults.java:133)
at javax.swing.UIDefaults.getUI(UIDefaults.java:742)
at javax.swing.UIManager.getUI(UIManager.java:1001)
at com.l2fprod.common.swing.plaf.LookAndFeelAddons.getUI(LookAndFeelAddons.java:270)
at com.l2fprod.common.swing.JTaskPane.updateUI(JTaskPane.java:121)
at com.l2fprod.common.swing.JTaskPane.<init>(JTaskPane.java:111)
at com.reefangel.tool.Wizard.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:682)
at java.awt.EventQueue.access$000(EventQueue.java:85)
at java.awt.EventQueue$1.run(EventQueue.java:643)
at java.awt.EventQueue$1.run(EventQueue.java:641)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:652)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.l2fprod.common.swing.plaf.LookAndFeelAddons.getUI(LookAndFeelAddons.java:275)
Re: Need Help with Setup
Can I see the code you are trying to upload?
Gideon1
Post by Gideon1 »
Hi Thanks for getting back with me. I have unintalled RA+ on my OSX and I am using Paralles 7 win Ardunio for inniall setup it's much easier it seems, i'll keep you posted. Q: relay box is making clicking sounds?
That's the sound of relays clicking.
The preloaded code comes with wavemaker ports that alternate every few seconds.
Gideon1
Post by Gideon1 »
I followed instruction to the key but still get "No internal Memory Found" on the RA+ display? What am I doing wrong
Thx
Gideon1
Post by Gideon1 »
Heres whats on the Ardunio:
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.StandardLights( Port2,21,0,7,0 );
ReefAngel.StandardLights( Port3,7,0,21,0 );
ReefAngel.StandardLights( Port4,7,0,21,0 );
ReefAngel.Portal( "Gideon1" );
You missed the step where you have to upload the internal memory.
http://www.reefangel.com/Support.Loadin ... tings.ashx
Gideon1
Post by Gideon1 »
RA wisdor says download completed successfully but RA + displays say "No internal memory found" Joy stick no response. What is going on here...plese help Thanks!
Gideon1
Post by Gideon1 »
rimai...thanks it appears to be up and running. I have to test and make adjustment now....you are great! Thanks Now i need to setup my wiifii :)!
Gideon1
Post by Gideon1 »
Status light is red on RA + ? what does this mean?
ATO timeout.
Gideon1
Post by Gideon1 »
Hi rami,
I am unable to setup my wifii. Here are the codes what am i doing wrong Thx:
InternalMemory.OverheatTemp_write( 807 );
The code has nothing to do with how you setup your wifi.
Did you read the manual?
Also, please check this thread:
http://forum.reefangel.com/viewtopic.php?f=15&t=345
Gideon1
Post by Gideon1 »
Can't connect to wifi followed steps, my home network is via time capsule wired to my FIOS router, when i type SSID and password for my home network does not connect, or should it be my FIOS i connect too???... :? tired that too no connection, i get a slow green blinking light on the wifi unit? How do i connect, and resolve the issue. I did port forwarding to port 2000, to no avail. I do not know what I'm doing wrong. Please help.
~ben
If you get slow green and no blue, you should be connected to your wifi.
Can you see the wifi attachment in your attached devices of your router?
Gideon1
Post by Gideon1 »
I do get a slow green light but all "false indicators" with wifi status, do i need to upload test for wifi page?
Gideon1
Post by Gideon1 »
if connected to wifi sholud I still be getting "Unreachable Address" in portal, i can't update, and still get false indicators ie wifi status: Auth...etc
Oh, if you are getting false on auth and dhcp and 0.0.0.0 ip address, then something is not setup right, indeed.
Can you try another wifi utility?
https://github.com/davemolton/Graphical ... ves/master
Try setting up with Daves wifi utility.
Make sure you connect at 57600 baud.
Gideon1
Post by Gideon1 »
I can not verify wifi is setup...please help
alexwbush
Post by alexwbush »
what is the utility telling you?
http://forum.reefangel.com/viewtopic.php?f=15&t=345 <-pretty straight forward
