Wizard
- Saltgator
Wizard
While working with wizard, how do I upload (change) the settings? I went thru all 8 steps (changing each relay's function) and nothing changed, and it simply brought me back to step 1.
Also, how many posts does it require for me to unlock sending PMs?
Country Boy using tapatalk on his EVO
- Saltgator
Re: Wizard
Thanks.rimai wrote:You just keep clicking next and it should let you upload.
3 posts for PM
- Saltgator
Re: Wizard
Just tried the Wizard. Now when it tries to upload I recieve a error. I'll try to post a the codes in a minute. The 1st attempt stated it couldn't locate the serial port.
ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,13,30,22,30 );
ReefAngel.StandardLights( Port2,13,0,22,0 );
ReefAngel.StandardLights( Port3,23,0,8,0 );
ReefAngel.StandardHeater( Port4,760,780 );
ReefAngel.StandardHeater( Port5,760,780 );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,54, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,54, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
// Date and Time
int x,y;
// Parameters
// pH Expansion
// Water Level
// Main Relay Box
// Relay Expansion
// Date and Time
- Saltgator
Re: Wizard
It's now stating that it can't communicate with the device.
Re: Wizard
Did you select the correct board and serial port on menu Tools->Board and Tools->Serial Port?
- Saltgator
Re: Wizard
No sir. Newbie should be my issue,lol. I'll try it again.rimai wrote:Did you select the correct board and serial port on menu Tools->Board and Tools->Serial Port?
- Saltgator
Re: Wizard
Ok, I guess I'm really a newbie. I gave the switching ports a try and both give me an error after uploading.
ReefAngel.StandardLights( Port1,16,0,22,0 );
ReefAngel.StandardLights( Port2,17,0,21,0 );
ReefAngel.StandardLights( Port3,23,0,11,0 );
int x,y;
// Parameters
// pH Expansion
// Water Level
// Main Relay Box
// Relay Expansion
// Date and Time
int x,y;
// Parameters
// pH Expansion
// Water Level
// Main Relay Box
// Relay Expansion
// Date and Time
Re: Wizard
Do you have RA or RA+?
Make sure you have the correct board selected under Tools->Board
- Saltgator
Re: Wizard
RA+. I checked that too, it was correct.rimai wrote:Do you have RA or RA+?
