Reef Angel Wifi Adress
PostPosted: Mon Jun 10, 2019 12:11 pm
Hi Guys
How do I change my Reef Angel wifi address in the Portal
PostPosted: Mon Jun 10, 2019 5:17 pm
It does it automatically as soon as your RA connects to the server
PostPosted: Thu Jun 13, 2019 2:55 am
Okay. Thanks. But Still struggling
PostPosted: Thu Jun 13, 2019 3:00 am
When setting up my Wifi attachment, The Wifi wizard goes thru everything
Everything is true getting IP adress ect. but the bottom line reads....
Trying to connect to your router..........
PostPosted: Thu Jun 13, 2019 8:32 am
Try this:
viewtopic.php?f=3&t=4601
PostPosted: Fri Jun 14, 2019 2:29 am
Thanks! Will givecit a go....
Just one think... I says trying to connect to router
But I have a slow flashing green LED. That means its
Connected Right? But is trying to connect to router.
Strange
PostPosted: Wed Jun 19, 2019 9:49 am
rimai wrote:Try this:
Okay.... I installed teraterm, downloaded the zip file, made changes as nessasary,
Changed baud rate to 57600, and ran the macro.
Macro ran Fine... Everything read “AOK” But now my WiFi attachment has a blinking
Blue and Green Light.
What to do Now?
PostPosted: Wed Jun 19, 2019 9:56 am
Did you change the ssid and password?
It is case sensitive.
PostPosted: Wed Jun 19, 2019 7:26 pm
rimai wrote:Did you change the ssid and password?
Yes. SSID and Passphrase changed
PostPosted: Wed Jun 19, 2019 8:40 pm
Do you happen to have a space?
If so, you need to use $ instead of space.
Next
Return to Ask anything here
Users browsing this forum: No registered users and 6 guests
