Posts: 209 Joined: Fri Dec 26, 2014 6:38 pm
 Posted: Mon Jan 31, 2022 10:14 pm
- Code: Select all
#include <ReefAngel_Features.h> #include <Globals.h> #include <RA_Wifi.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_NokiaLCD.h> #include <RA_ATO.h> #include <RA_Joystick.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <InternalEEPROM.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <Salinity.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <Humidity.h> #include <DCPump.h> #include <PAR.h> #include <ReefAngel.h>
void SeasonalTemps () { static int heatArray[][2] = { {780,784},// default in case of error in month=0 (May) {764,768},//January (winter) {768,772},//February (winter) {772,776},//March (early spring) {776,780},//April (spring) {780,784},//May (spring) {784,788},//June (early summer) {788,792},//July (summer) {784,788},//August (summer) {780,784},//September (early fall) {776,780},//October (fall) {772,776},//November (fall) {768,772} };//December (early winter) ReefAngel.StandardHeater( Port1,heatArray[month()][0],heatArray[month()][1]); }//end seasonalTemps
void setup() { // This must be the first line ReefAngel.Init(); //Initialize controller ReefAngel.Use2014Screen(); // Let's use 2014 Screen // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = Port5Bit; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = Port1Bit | Port2Bit; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE;
// Feeeding and Water Change mode speed ReefAngel.DCPump.FeedingSpeed=0; ReefAngel.DCPump.WaterChangeSpeed=0;
// Ports that are always on ReefAngel.Relay.On( Port2 ); ReefAngel.Relay.On( Port5 );
////// Place additional initialization code above here }
void loop() { SeasonalTemps(); ReefAngel.ActinicLights( Port3 ); //Skimmer ReefAngel.DayLights( Port4 ); //ATS light ReefAngel.DosingPumpRepeat1( Port6 ); //ReefAngel.DosingPumpRepeat2( Port7 ); ReefAngel.DosingPumpRepeat3( Port8 ); ReefAngel.PWM.DaylightPWMParabola(); ReefAngel.PWM.ActinicPWMParabola(); ReefAngel.DCPump.UseMemory = true; ReefAngel.DCPump.LowATOChannel = Sync; // SW 8 ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8 //ReefAngel.DCPump.AntiSyncOffset = 125; // % (0-255) of main pump (Sync)
////// Place your custom code below here // koralia 1150 // if (hour()>=23 || hour()<11) ReefAngel.Relay.Off( Port5 ); // else ReefAngel.WavemakerRandom( Port5, 120, 1800 ); // kalk reactor if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off( Port7 ); //kalk dosing off 5pm-11pm else ReefAngel.DosingPumpRepeat2( Port7 ); // DC pumps // To run this code must choose Custom in portal static int rmode; static boolean changeMode=true;
// These are the modes we can cycle through. You can add more and even repeat... byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
if (now()%3600==0 || changeMode==true) { // Change every 60 mins (3600seconds) or controller reboot rmode=random(100)%sizeof(modes); // Change the mode by picking from our array changeMode=false; }
// Set timer when in feeding mode static unsigned long feeding; if (ReefAngel.DisplayedMenu==FEEDING_MODE) feeding=now(); // Continue NutrientTranspot Mode for 30 minutes after feeding if (now()-feeding<1800) { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read(); ReefAngel.DCPump.Mode=Else; ReefAngel.DCPump.Speed=80; // Night mode (go to 30%) } else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11pm to 11am ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read(); ReefAngel.DCPump.Mode=Gyre; ReefAngel.DCPump.Speed=40; } else if (InternalMemory.DCPumpMode_read()==11) { // Custom Mode and nothing else going on ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read(); ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :) ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Set speed from portal } else { ReefAngel.DCPump.UseMemory=true; // Will reset all values from memory }
