Replacement dosing pump Silicone tubes?
PostPosted: Thu Aug 02, 2012 8:06 pm
Man...the turth is I don't know how or where to place the code...I'm no coder (first time) It took awhile to just set it up with the perset codes w/ rimai's help. I would be fooling myself if I tried the above by myself. :(
Thanks for getting back with me so qiuck though :)
PostPosted: Thu Aug 02, 2012 8:26 pm
Just add the hard coded option given above in your code where your code says "Place your custom code below here" and above the line "Place your custom code above here"
PostPosted: Thu Aug 02, 2012 8:28 pm
binder: I think i did it. I had to swich port functions b/c I hooked up the 2-part I-Bionic backwards, so dose 2 comes on frist port-8 @ 7am (alk. comp#1) and then dose-1 comes on (cal.-comp#2 on port-7, 5 min delay. Here is the code if you see a problem please correct Thanks!:
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 801 );
ReefAngel.Relay.On( Port5 );
// Port 7, timer 1, 7:00a, run for 7 seconds
ReefAngel.DosingPump(Port7, 2, 7, 5, 7);
// Port 8, timer 2, 7:05a, run for 7 seconds
ReefAngel.DosingPump(Port8, 1, 7, 0, 7);
ReefAngel.StandardLights( Port2,20,0,7,0 );
ReefAngel.StandardLights( Port3,7,0,20,0 );
ReefAngel.StandardLights( Port4,7,0,20,0 );
ReefAngel.DosingPumpRepeat( Port7,0,1,7 );
ReefAngel.DosingPumpRepeat( Port8,0,1,20 );
ReefAngel.Portal( "Gideon1" );
PostPosted: Thu Aug 02, 2012 8:39 pm
Almost there, but you are getting the hang of it :)
Good job!!!
The correct code would be like this:
PostPosted: Thu Aug 02, 2012 8:44 pm
opps!...the above code placement was wrong plus i had the code for dosing in there twcie here is the corrected code and placement. Please check and give feed back Thanks!
~ben
PostPosted: Thu Aug 02, 2012 9:20 pm
does it matter what part you dose 1st ---part 1 or part 2???
~ben
PostPosted: Sat Aug 04, 2012 7:13 am
hi...i set the below code in the 'Custom Code' section in wisdor, but when i adjust lights or another fountion in wisdor, then update, it swips out the custom code back to the defualt code in wisdor. I want to control dosing pumps from memory but have no idea where i should place the code and/or set the internal memory values for the DP1OnHour, DP1OnMinute, DP1Timer, DP2OnHour, DP2OnMinute, DP2Timer values to be 7am and 7:05am with timer values of 7 seconds. Can someone code the below so i can cut/paste it in memory, and it will reoccur even if i adjust some other funtion in wisdor it will remain constant. Also, i had to which around the below code as i setup i-bionic 2-part backwards on the pumps. i just don't know where to place the values in the internal memory....thanks for your help--
PostPosted: Sat Aug 04, 2012 8:51 am
The wizard will always generate new code. It cannot keep the custom code you add manually after it has generated.
If you want to use internal memory, use this:
ReefAngel.DosingPump2(Port7);
ReefAngel.DosingPump1(Port8);
To change those values, you have two options:
1. Android app
2. Java status app
PostPosted: Sat Aug 04, 2012 9:06 am
Ok...how do i access those options?
Thx
Return to Ask anything here
