programming via wireless
PostPosted: Fri Jul 06, 2012 12:52 pm
Is it possible to program the controller via the wireless interface?
It's very difficult to keep unplugging the wireless module to update the programming.
Also I received a cord with a usb connector on one end and a three pin female connector on the other end. The connector on the other end looks like the same connector that is used on the temperature sensors. What is this cable for?
PostPosted: Fri Jul 06, 2012 2:46 pm
It is not possible to load codes through the wifi attachment.
The cable is a USB power cable.
You can use it to power your unit without the relay box.
Return to Ask anything here
