Need Help with Setup
PostPosted: Mon Jul 30, 2012 7:00 pm
ATO timeout.
PostPosted: Mon Jul 30, 2012 7:53 pm
Hi rami,
I am unable to setup my wifii. Here are the codes what am i doing wrong Thx:
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 807 );
ReefAngel.StandardLights( Port2,21,0,7,0 );
ReefAngel.StandardLights( Port3,7,0,21,0 );
ReefAngel.StandardLights( Port4,7,0,21,0 );
ReefAngel.Portal( "Gideon1" );
PostPosted: Mon Jul 30, 2012 7:59 pm
The code has nothing to do with how you setup your wifi.
Did you read the manual?
Also, please check this thread:
viewtopic.php?f=15&t=345
PostPosted: Tue Jul 31, 2012 10:20 am
Can't connect to wifi followed steps, my home network is via time capsule wired to my FIOS router, when i type SSID and password for my home network does not connect, or should it be my FIOS i connect too???... :? tired that too no connection, i get a slow green blinking light on the wifi unit? How do i connect, and resolve the issue. I did port forwarding to port 2000, to no avail. I do not know what I'm doing wrong. Please help.
~ben
PostPosted: Tue Jul 31, 2012 10:23 am
If you get slow green and no blue, you should be connected to your wifi.
Can you see the wifi attachment in your attached devices of your router?
PostPosted: Tue Jul 31, 2012 10:53 am
I do get a slow green light but all "false indicators" with wifi status, do i need to upload test for wifi page?
PostPosted: Tue Jul 31, 2012 11:19 am
if connected to wifi sholud I still be getting "Unreachable Address" in portal, i can't update, and still get false indicators ie wifi status: Auth...etc
PostPosted: Tue Jul 31, 2012 11:35 am
Oh, if you are getting false on auth and dhcp and 0.0.0.0 ip address, then something is not setup right, indeed.
Can you try another wifi utility?
https://github.com/davemolton/Graphical ... ves/master
Try setting up with Daves wifi utility.
Make sure you connect at 57600 baud.
PostPosted: Tue Jul 31, 2012 3:09 pm
I can not verify wifi is setup...please help
PostPosted: Wed Aug 01, 2012 11:16 pm
what is the utility telling you?
viewtopic.php?f=15&t=345 <-pretty straight forward
Previous
Return to Ask anything here
