can't connect with the portal
Re: can't connect with the portal
Yes, good job.
It's a very good start!!!
You placed it in the right spot too :) Good job.
The reason I asked if you have RA or RA+ is that we will need to remove some stuff to get the wifi to fit in the memory.
So, you need to remove these 2 lines:
ReefAngel.AddStandardMenu();
 ReefAngel.AddDateTimeMenu();
That should let you upload the code.
Bogdan
Post by Bogdan »
OK, it is uploaded and I can see the parameters on the ReefAngel Client. Thanks
Now, next problem is I wanted to change some of the setting in the preloaded code.
I was able to do that yesterday directly on the controller but now I can't. The Settings are gone.
This is the drawback of having the wifi code added to the controller.
You can only fit so much in the standard RA.
On the RA+ you would be able to fit everything, but with the standard RA, you will need to make a choice of changing settings on the controller or using the Client.
You can use the Client to change the settings though.
You can click the memory tab and change them right there.
Bogdan
Post by Bogdan »
Is this the place I can change the setting?
Yes, but make sure that all fields are populated or it will generate an error.
Use 540 for pH7 and 830 for pH 10 as default calibration numbers.
Bogdan
Post by Bogdan »
If I do the adjustments and save it, and then disconnect the comp from the controller or turn off the comp are they still going to be working? Is this going to be save in the controller memory?
The dosing pumps, what should I write there if I want to disable them?
Yes, but it will stop sending data to the Portal.
I thought the whole purpose of this was to get you data on the Portal, wasn't it?
Bogdan
Post by Bogdan »
Yes you are right, but this is connected to my laptop which I occasionally take to work so I need to disconnect the controller.
Bogdan
Post by Bogdan »
Just leave them the way it is.
It won't do anything. You are not using those settings.
Bogdan
Post by Bogdan »
OK
After adjusting the setting I clicked save. Should I now go to setting and click load memory file?
No. That's all to it.
Bogdan
Post by Bogdan »
OK, thanks for your patience. I know I will have more questions soon. You have a good night.
