Need custom code for custom expansion
Re: Need custom code for custom expansion
Let's see some pics of what you've accomplished AuqaO
AquaO
Post by AquaO »
Yes I will post pictures later I need to fix some detail.
Thank you for your interest.
Eric
Osaka 40g with 55g sump
Radion, 2X Tunze 6045, Swc-160 mini cone
Yeah, very interested to see what you did with the dosing pumps... what pumps are you using.
I'm currently investigating how to dose, and not thrilled with the idea of wasting outlets (want to do triple channel) and having to waste all those relay ports. I like the standalone controllers like Bubble Magus, but sooo expensive. Considering the chinese knock-off Marine Magic which looks good, but I feel like it's such a waste having the RA that could do all that...
The RA dosing pump should connect to the PWM ports and have a PWM driver. If it was controllable like that or directlyw ithout the dimming module, I'd be snatching it up in a heartbeat. So very curious on the details here...
Edit: From the store-front, the previosly out-of-stock dosing pump looks like it's been replaced.. any details? It looks like the slave pump from another dosing pump i've seen...
I have a triple magic dosing set up and to be honest it sucks. Every doser gives out different amounts. So you have to do some serious math for two part dosing. And they like to wear down and dose less and less and then you have to adjust the speed settings/recalculate again and the cycle repeats. Just FYI
AquaO
Post by AquaO »
Because a picture is worth a thousand words ;)
Do not forget is in progress.
Here is the dosing pump I use
(purchased on eBay)
Here is my DiY case
And Video
http://youtu.be/oV4HXv71SxQ
no pics :(
Where'd you get the bare doser motor? 12v I'm assuming?
AquaO
Post by AquaO »
I corrected the link of the pics, sorry
I bought the motor on ebay, I believe that it is the same as Profilux.
Yes they are 12v
I was also working to change the speed of the motor manually, for avoided programming all the time.
So jealous...I need an Uno now...:(
Good DIY!!!
AquaO,
That is awesome! I just bought a few of those pumps, actually I bought the $30 ones that are already in an encosure with a potentiometer. I would love to convert it at some point to do what you did and control them individually with PWM instead of relays on my outlet strip...
Do you think you could do a more comprehensive post on what you did to setup the UNO? Do you know what would be needed if I wanted to just integrate with the RA Dimming module?
Thanks in advance and again awesome job!
Edit: Wow, the UNO is only $35... I'd gladly purchase one of these if I knew what to do with it!
I'm also interested on seeing how you are powering the motors. Did you use a mosfet transistor?
AquaO
Post by AquaO »
rimai wrote:I'm also interested on seeing how you are powering the motors. Did you use a mosfet transistor?
No I use a NPN transistor TIP-122
Here is the wiring I did
Thank you very much for your comment
AquaO
Post by AquaO »
For control motor speed with PWM you need:
1x NPN transistor TIP-122
1x Capacitor 1uf
1x Diode
1x Resistor 1k ohm
And the diagram
For make your own USB cable for communication RA/Uno
You need:
1x Regular USB cable and strip it
2x Resistor 1.5k ohm
And the diagram
AquaO
Post by AquaO »
Hi guys, I did some experiment for you. And the good news, you can use the dimming ports of Reef Angel to control the motor speed. You do not need an Arduino Uno. The Reef Angel and pwm expansion module is ready for this use.
Here the diagram
And the video
http://youtu.be/Zo3RXFuEGlI
I think if would be great for an update of RA dosing pump ;)
There you go roberto! Wire that into the circuit for of the ra dosing pump add a switch for controlled or independent mode and done deal!!!
AquaO
Post by AquaO »
I need your help, I'm not very good with the RA code.
I would like to know if it's possible to add to the menu PWM port and change the name in the menu?
Ex: instead of Ch 0, Ch 1, Ch 2 and Ch 3
I would like Alk, Ca, Mg and Carb and to modify the duration and %
Ex: Alk 15sec at 100% or Ca 20sec at 60%
Thank you in advance
Eric
This is my RA code
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.DosingPumpRepeat( Port8,0,60,60 );
    ReefAngel.PWM.SetChannel( 0, now()%3600<15?80:0);
    ReefAngel.PWM.SetChannel( 1, now()%3600<25?50:0);
    ReefAngel.PWM.SetChannel( 2, now()%3600<35?95:0);
    ReefAngel.PWM.SetChannel( 3, now()%3600<10?100:0);
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
I'm assuming you are talking about changing the main screen, right?
http://forum.reefangel.com/viewtopic.php?f=14&t=109
AquaO
Post by AquaO »
Yeah and change the value of PWM expansion, on ch0, ch1, ch2, ch3 directly on PDE.
AquaO
Post by AquaO »
rimai wrote:I'm assuming you are talking about changing the main screen, right?
thank you I'll try to make my own main screen and menu.
