Programming language
baroutas
Post by baroutas »
Hi! Witch programming language use the RA, for coding?
C++
baroutas
Re: Programming language
Post by baroutas »
Thanks lnevo!!!!! I start reading for C++ and a hope to learn how make a code.....!
You really don't need too much experience. Theres a lot of example code on the site and the wizard gives a great starting point. It's mostly if/then statements for most of it!
baroutas
Post by baroutas »
Thanks again! I try to understand how the code works because I'm totally clueless
What are you trying to do?
baroutas
Post by baroutas »
Nothing yet!! Just trying to understand how does the code work to RA? Maybe later I will try to write some codes.
