how to increase the actinic lights on time?
PostPosted: Mon Nov 05, 2012 7:01 pm
How do I increase the light time for actinic light. Right now the difference is 30 min. that is the actinic are on 30 min before std. lights and off 30 min after the std. lights. I want to increase the difference to 60 min. I understand that it can't be done via the portal. Only the timing for std. lights can be change on portal. The MH lights setting do nothing. I guess I need to get into the program to change the default 30min to 60min. How do I do that, I don't even remember how to get into the program on the arduino. Can you help?
PostPosted: Mon Nov 05, 2012 7:04 pm
You can change the offset on the portal in the same window..
PostPosted: Mon Nov 05, 2012 7:08 pm
How?
PostPosted: Mon Nov 05, 2012 7:48 pm
On the portal click on Internal Memory, then under lighting. It shows the standard light time an the Actinic offset..
PostPosted: Mon Nov 05, 2012 8:08 pm
Well I do not have WiFi attachment so it doesn't work. I was thinking about the RA Client rather sorry for misleading.
PostPosted: Mon Nov 05, 2012 8:51 pm
Try ReefAngel.InternalMemory.ActinicOffset_write(60); put whatever number you need.
Return to Ask anything here
