two questions
PostPosted: Sat Dec 01, 2012 11:11 am
Two questions about some issues that I now appear.
Reefangelstatus still works for the new version of libraries?
to generate code from reefangelwizard compiles perfectly but if I choose the option to compile and load I get an error, if the same file over from arduino load correctly
PostPosted: Sat Dec 01, 2012 12:08 pm
Picard wrote:Reefangelstatus still works for the new version of libraries?
Yes, it still does. You should use the latest (beta 2 I believe). The only change that you will need to make is to goto the Edit menu and choose Settings. Then UNCHECK the "use pre v1.0 memory locations". This will allow it to work on versions 1.0 and later. This only applies to the memory locations.
Return to Ask anything here
