Re: two questions
Posted: Sat Dec 01, 2012 12:08 pm
Yes, it still does. You should use the latest (beta 2 I believe). The only change that you will need to make is to goto the Edit menu and choose Settings. Then UNCHECK the "use pre v1.0 memory locations". This will allow it to work on versions 1.0 and later. This only applies to the memory locations.Picard wrote:Reefangelstatus still works for the new version of libraries?
