COUPLE QUICK QUESTIONS
Posted: Wed Dec 12, 2012 1:33 pm
I have just a few questions for anyone who may know the answer or can help. thanks in advance
1. Can I do an overheat clear from the portal online or from my phone app while im away from home to get my
halides to come back on without having to manually clear it at home on the controller itself?
2. Im currently not using my 2 float switchs that came with my RA but would like to use them just as a means to monitor my water level if it get to low and that the water level is staying put. So I would like to utlize them as monitors is all. Anyhow can somone give me the code that I need to input into mine and weres about to place the code. thanks
my current code example:
ReefAngel.FeedingModePorts = Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port8Bit;
ReefAngel.Init();
ReefAngel.AddWifi();
ReefAngel.MHLights( Port1,13,0,19,0,15 );
if ( hour() >=20 || hour() < 5)
ReefAngel.DosingPumpRepeat( Port2,0,60,240 );
ReefAngel.Relay.Off( Port2 );
if ( hour() >=9 && hour() <18)
ReefAngel.DosingPumpRepeat( Port3,0,60,240 );
ReefAngel.Relay.Off( Port3 );
ReefAngel.StandardFan( Port4,785,789 );
ReefAngel.StandardHeater( Port5,780,783 );
if (( hour()==10 && minute()<15) || (hour()==13 && minute()<15))
ReefAngel.Relay.Off (Port6);
ReefAngel.Relay.On (Port6);
ReefAngel.StandardLights( Port7,17,0,10,0 );
ReefAngel.MHLights( Port8,13,0,19,0,15 );
ReefAngel.Portal( "iceman330824" );
ReefAngel.Init();
