Are you able to load any code the controller?
It looks like you got the wrong com port.
Very much problems with rawizard & rastatus
Re: Very much problems with rawizard & rastatus
Ra status only works with wifi. It doesn't work with serial.
Did you try using the portal?
Sent from my Galaxy S3 using Tapatalk 2
Did you load the sample code to initialize all the memory variables. I forget the name of the sketch, but if you missed this step, you could have problems.
