Wizard
Saltgator
Wizard
Post by Saltgator »
While working with wizard, how do I upload (change) the settings? I went thru all 8 steps (changing each relay's function) and nothing changed, and it simply brought me back to step 1.
Also, how many posts does it require for me to unlock sending PMs?
Country Boy using tapatalk on his EVO
Re: Wizard
You just keep clicking next and it should let you upload.
3 posts for PM
Saltgator
Re: Wizard
Post by Saltgator »
rimai wrote:You just keep clicking next and it should let you upload.
3 posts for PM
Thanks.
Saltgator
Re: Wizard
Post by Saltgator »
Just tried the Wizard. Now when it tries to upload I recieve a error. I'll try to post a the codes in a minute. The 1st attempt stated it couldn't locate the serial port.
ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,13,30,22,30 );
ReefAngel.StandardLights( Port2,13,0,22,0 );
ReefAngel.StandardLights( Port3,23,0,8,0 );
ReefAngel.StandardHeater( Port4,760,780 );
ReefAngel.StandardHeater( Port5,760,780 );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,54, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,54, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
// Date and Time
Saltgator
Re: Wizard
Post by Saltgator »
It's now stating that it can't communicate with the device.
Re: Wizard
Did you select the correct board and serial port on menu Tools->Board and Tools->Serial Port?
Saltgator
Re: Wizard
Post by Saltgator »
rimai wrote:Did you select the correct board and serial port on menu Tools->Board and Tools->Serial Port?
No sir. Newbie should be my issue,lol. I'll try it again.
Saltgator
Re: Wizard
Post by Saltgator »
Ok, I guess I'm really a newbie. I gave the switching ports a try and both give me an error after uploading.
ReefAngel.StandardLights( Port1,16,0,22,0 );
ReefAngel.StandardLights( Port2,17,0,21,0 );
ReefAngel.StandardLights( Port3,23,0,11,0 );
int x,y;
// Parameters
// pH Expansion
// Water Level
// Main Relay Box
// Relay Expansion
// Date and Time
Re: Wizard
Do you have RA or RA+?
Make sure you have the correct board selected under Tools->Board
Saltgator
Re: Wizard
Post by Saltgator »
rimai wrote:Do you have RA or RA+?
RA+. I checked that too, it was correct.
