portal problems?
PostPosted: Sat Jan 19, 2013 2:46 pm
I am just setting up my Client Suite as well to talk to the portal and am getting the same errors in the log as Bogdan.
I have my portal name and security key in both the Client Suite and in the Controller code.
Do you need any port forwarding for the client to work with the portal ?
Mike
75G with 30G sump | 52 LED - RapidLED Lighting (DIY) |
ReefAngel for Meanwell ELN-D Drivers | Reef Octopus HOB-1000
Way to much time and money invested.....
PostPosted: Sat Jan 19, 2013 2:49 pm
Have ya'll tried turning off the security key in the controller code and on the portal?
d
PostPosted: Sat Jan 19, 2013 2:57 pm
Trying it now.
PostPosted: Sat Jan 19, 2013 3:08 pm
No Joy :) -
So I just learned the hard way that you have to have ReefAngel.Portal ( "userid "); in the controller code for it to load the wifi module.
I removed the key in both the controller and Client and still not working.
However I should mention that the LABELS did update on the portal to what I have in the Client. But no other data.
PostPosted: Sat Jan 19, 2013 3:49 pm
Good to know. Did you turn off the key on the portal too?
PostPosted: Sat Jan 19, 2013 3:54 pm
I wonder if you need to apply the ini file in this post:
viewtopic.php?p=16602#p16602
PostPosted: Sat Jan 19, 2013 4:27 pm
Dbmet - I did remove the key from the portal - good catch tho
Rimai - I will try the INI file now.
PostPosted: Sat Jan 19, 2013 4:32 pm
Hope that works. Good luck.
PostPosted: Sat Jan 19, 2013 4:38 pm
Loaded it INI - It fixed the issue with the error on loading the memory page. That works now ( although it has wrong information in the fields).
It did not fix the upload to the portal. Same error.
Message:
Value cannot be null.
Parameter name: s
StackTrace:
at System.IO.StringReader..ctor(String s)
at NotificationService.Notifier.SendParamsToWebsite()
PostPosted: Sat Jan 19, 2013 6:34 pm
Loaded the new RAMmemory and it says new memory file successfully verified and loaded.
Then when I click Memory on client and refresh I got this"
Return to Ask anything here
