portal problems?
PostPosted: Sat Jan 19, 2013 6:35 pm
And then in log error I see this:
PostPosted: Sat Jan 19, 2013 7:02 pm
Did you close and restart the client software after loading the new memory file? I actually rebooted just to make sure everything was clean. Then mine stated working.
75G with 30G sump | 52 LED - RapidLED Lighting (DIY) |
ReefAngel for Meanwell ELN-D Drivers | Reef Octopus HOB-1000
Way to much time and money invested.....
PostPosted: Sat Jan 19, 2013 7:08 pm
I closed and restarted, no help. Then rebooted the comp, no help.
Now the general settings on Client work but can't refresh memory or access it at all.
PostPosted: Sat Jan 19, 2013 10:23 pm
We are going to have to wait for Dave to check it out...
I'm out of ideas.
PostPosted: Sun Jan 20, 2013 12:09 pm
OK, any idea when he can show up?
PostPosted: Sun Jan 20, 2013 2:18 pm
Waiting ..
I have tried and retried everything I can think of.
PostPosted: Sun Jan 20, 2013 4:55 pm
I see what the issue is. It will require a software patch. Working on it now.
PostPosted: Sun Jan 20, 2013 5:21 pm
OK, great.
PostPosted: Sun Jan 20, 2013 8:05 pm
Okay, sorry for the issues you experienced with the Client. To keep things simple, I created a new installer that includes the changes that should fix parameter syncing to the portal over USB. From the control panel, please first uninstall your current version of the Client Suite, download and install the new one located here: https://github.com/davemolton/Client-Su ... ta_301.zip
PostPosted: Sun Jan 20, 2013 8:43 pm
You fixed it, as you can see in the signature area, the banner shows data up to date.
However I still can't open my memory on Client, when I click refresh I get the the same message and error log file like above in this thread. Sorry to cause so much trouble.
Return to Ask anything here
Users browsing this forum: Google [Bot] and 1 guest
