charts not updating
Bogdan
charts not updating
Post by Bogdan »
My Client get stuck all the time and is not updating the charts. I have to go to setting, controller and click show date and time then it will update the chart. I dont have wifi, the RA is connected via USB cable. Libraries and software updated to the newest version. The code was recently generated by use of the wizard. Everything works like it should except the client which do not updates the readings/charts. Sometime it keeps updating the readings for a few hours then stops. You can see it on the chart as a strait line.
Bogdan
Re: charts not updating
Post by Bogdan »
Could you suggest something that I should check, change, correct to get the client working smoothly? I would appreciate any help with this problem.
dmolton
Post by dmolton »
So the chart stops updating for a few hours and then resumes automatically?
Can you attach or PM the error log?
Bogdan
Post by Bogdan »
Attached is the error log file (pdf). This is just from one day.
It does not resume automatically even after several hours. I need to manually click setting, controller, show data and time, then it updates but obviously it is a strait line.
error log from 28 January.pdf
(749.31 KiB) Downloaded 383 times
Bogdan
Post by Bogdan »
Can somebody help please.
Bogdan
Post by Bogdan »
bump
dbmet
Post by dbmet »
You will have to wait for him to help.. I don't have the client even installed... What all do you use the client for?
d
Bogdan
Post by Bogdan »
I use the client for almost everything eg.
1. to monitor the temp and pH
2. to adjust the parameters (pH, lights, et cetera)
3. to send the notifications (alarms) to my email
4. to monitor the parameters on my cell
5. to turn on/off pumps lights if needed (the arduino display is too small for me to work with it)
My laptop is connected via usb with the RA all the time.
dbmet
Post by dbmet »
Cool Was just curious as I'm on a mac and I don't have the Client...
d
Bogdan
Post by Bogdan »
bump
Bogdan
Post by Bogdan »
bump
Paulturner911
Post by Paulturner911 »
How can I download this?
