A Little help PLEASE
PostPosted: Tue Jan 29, 2013 1:59 pm
Each port can output 40mA.
The meanwell drivers I think draws about 4mA each.
RA moonlight draws about 25mA
PostPosted: Tue Jan 29, 2013 2:38 pm
I would be controlling them seperate (3-W,B,ML). How many ports are on the RA+ out of the box? I cannot tell in the picture. How exactly are they controlled? I see it looks like landing terminals for 18g wire, what about the 120 plug? Does the 120v go in to my relay module and the driver output go into the PWM controller and then an output from the PWM module to my CREE PCB? Sorry to ask soo many questions, I just dont want to be pulling the trigger on the incorrect unit.
PostPosted: Tue Jan 29, 2013 4:10 pm
There are two ports on the relay box itself. The pwm module has 6. The 120v can either go to a relay or uncontrolled outlet somewhere else.
PostPosted: Tue Jan 29, 2013 4:11 pm
Your driver should have 6 wires... AC in +/-. LED +/- and DIM +/-
PostPosted: Tue Jan 29, 2013 7:01 pm
lnevo wrote:Your driver should have 6 wires... AC in +/-. LED +/- and DIM +/-
I see.. Thanks! I currently have MW lpc-35-700...which are not capable of dimming. I looking to place my order this week. I'm getting:
RA+ PWM
Moon light kit
A second temp probe for room temp
Wifi
Can anyone think of anything I'm missing? Any dongles, pigtails or extenders I may need. Any and all input would be great.
I'm really hoping this RAWizard is as simple as it sounds. I'm sure I'll stumble my way through it!!!
Thanks a bunch
PostPosted: Tue Jan 29, 2013 7:02 pm
dimming port lead wire
PostPosted: Tue Jan 29, 2013 7:17 pm
rimai wrote:dimming port lead wire
Noted. Thanks
PostPosted: Wed Jan 30, 2013 10:38 am
It looks like the Moon light kit comes with the dimming port lead wire. Is that correct? So I would only need to buy a single DPLW for the MW ELN driver?
PostPosted: Wed Jan 30, 2013 11:14 am
Yes.
Previous
Return to Ask anything here
