I had a single outlet go out on my power bar today. Just stopped working. It shows that it is working on the reef angel screen but no power. Can the outlet be replaced? I have tried to cycle the unit and single outlet on and off without success. Do I now just have a 7 outlet controller?
Thanks in advance for any help,
Chris
One of my outlets is not working.
Re: One of my outlets is not working.
What did you have connected in it?
Yes, the relay can be replaced.
http://forum.reefangel.com/viewtopic.php?p=14834#p14834
If you would like to send it for repair, please PM me.
I had the blue LED cord for the JBJ advanced plugged in, 4 Blue LEDs, plugged into port 8. If it wasn't a light, I probably wouldn't have noticed. Does anyone have a FAQ/writeup on how to replace the relay? I haven't looked at the relay box closely either. How does it open?
And I can't send a PM?
Prop it open, desolder the relay and solder a new one in its place.
PM is allowed after 3 posts.
- DrewPalmer04
cpace wrote: And I can't send a PM?
YOU'RE ALMOST THERE!! haha
But if you can solder...you're good to go!
Thanks for the info and hopefully this counts for my third post! I should be able to switch it out myself. Thanks for the help!
