Several Questions, new to reef angel
cody.sheridan-2008
Post by cody.sheridan-2008 »
Not sure how this Apogee PAR meter hooks in?
Not Sure if I have an analogue or PWM unit? Is there any way to tell?
more questions and pictures coming in next post... damn limits and no photobucket...
Cheers
Cody
cody.sheridan-2008
Re: Several Questions, new to reef angel
Worth noting I got the unit 2nd hand but new.
I got two probes with it.
I presume this is a PH probe, but the other one definitely is too. Will the other probe also work?
Cheers
Cody
fatman
Post by fatman »
Not sure on the PAR meter, but you likely have a PWM controller. The analog ones have a sticker on the relay box that says analog. You will only be able to run one pH probe without an expansion module.
cody.sheridan-2008
fatman wrote:Not sure on the PAR meter, but you likely have a PWM controller. The analog ones have a sticker on the relay box that says analog. You will only be able to run one pH probe without an expansion module.
Cheers, bugger was hoping for analog as I already have some drivers for it.
Cheers
Cody
