Ok so got the menu working thank you for that,
For the tunze I was unable to get the code working. All I did was paste it from someones post and I get an error.
a function-definition is not allowed here before '{' token
Really all I want to do is be able to set the speed. I don;t care about wavemaker and all that jazz. Just control the speed. Is there a simple code for that or instructions?
The wizard offers the AI cable support. Time to add the tunze option! You say it just needs a dimming port but there is no function built in to utilize that that I can find. Anyway here is the code I have now.
ReefAngel.FeedingModePorts = Port3Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port8Bit;
InternalMemory.OverheatTemp_write( 808 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,9,0,21,0 );
ReefAngel.SingleATO( true,Port8,30,0 );
ReefAngel.AddStandardMenu();
//Tunze short pulse functions
byte TunzeShortPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
byte tspeed=0;
PulseMinSpeed=constrain(PulseMinSpeed,0,100);
PulseMaxSpeed=constrain(PulseMaxSpeed,0,100);
tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
if (PulseSync)
return tspeed;
return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
ReefAngel.Portal( "cherub" );
