ph control
Barendvh
ph control
Post by Barendvh »
How does this control work?
Re: ph control
That's meant for equipment that raise pH.
Turn on when it gets lower than X pH and turns off when it gets higher than Y pH.
Barendvh
Re: ph control
Post by Barendvh »
Thank you Roberto is this based on the main pH reading or the PH expansion unit?
Re: ph control
main pH, but we can easily replicate that to work on the expansion too.
Barendvh
Re: ph control
Post by Barendvh »
Thank you I cannot program so I rely on the wizard. Is it easy to change? If not I am just going to keep the main tank on the expansion unit. What is the tolerances for the switching?
Re: ph control
You can code it as tight as you want, like turn on at 7.91 and off at 7.92, but that is going to give you a lot of turn on/off.
If you want to use the ph expansion module, you can add this to your code:
  if (ReefAngel.Params.PHExp <= 791) ReefAngel.Relay.On(Port5);
  if (ReefAngel.Params.PHExp >= 800) ReefAngel.Relay.Off(Port5);
Barendvh
Re: ph control switching
Post by Barendvh »
p
Hi I am still struggling to get the RA to switch on and off with the PH control
Please could you look at the code below and tell me what I am doing wrong
InternalMemory.OverheatTemp_write( 275 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port4,247,252 );
ReefAngel.StandardFan( Port5,255,260 );
ReefAngel.StandardLights( Port6,19,0,7,0 );
ReefAngel.PHControl( Port8,625,650 );
ReefAngel.Portal( "barendvh" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,75, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,75, ReefAngel.Params.PHExp );
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
Re: ph control
Which equipment are you trying to control based on pH?
PHControl is for equipments that raise pH and CO2Control is for equipments that lower pH.
Barendvh
Re: ph control
Post by Barendvh »
I am trying to control my calcium Reactor
Barendvh
Re: ph control
Post by Barendvh »
solinoid valve
Re: ph control
You must use the CO2Control and not PHControl.
Your equipment lowers pH.
Barendvh
Re: ph control
Post by Barendvh »
I am not measuring CO2
Barendvh
Re: ph control
Post by Barendvh »
I am trying to switch the solenoid of when the PH is 6.2 and on if the PH gets above 6.5.
Barendvh
Re: ph control
Post by Barendvh »
Re: ph control
Exactly... You are controlling something that lowers pH.
Barendvh
Re: ph control
Post by Barendvh »
So how should I do this
Barendvh
Re: ph control
Post by Barendvh »
Re: ph control
Use this:
ReefAngel.CO2Control ( Port8,625,650 );
Barendvh
Re: ph control
Post by Barendvh »
You are a absolute star it is working. Where are you in the world?
I am in South Africa
Re: ph control
Cool :)
Glad you got it working now. I'm in the USA
Barendvh
Re: ph control
Post by Barendvh »
Should you ever come to South Africa you are welcome to look me up.
Have a great day
