LED's?
Re: LED's?
rimai wrote:Well, my first attempt was a failure.
Let me investigate what went wrong.
oh no
Re: LED's?
Ok, so I had some time to go reasearch on why my 1st attempt was not successful and I realized that I missed an interesting point.
On my haste and excitement that they were using serial communication, I forgot to measure the voltage they are using.
According to the data I sniffed from their controller, they are using a very odd and non-standard serial protocol. They are inverting everything, which doesn't make sense.
Unless they actually using real RS-232 logic levels, instead of TTL levels.
So, I'm going to hack the code to invert the signals and head out to test again tomorrow.
Re: LED's?
I guess I just found out the answer of the inverted signal.
It does look like they indeed use RS-232 levels instead of UART levels
This is a photo from Neptunes website:
The cable connects to the serial port of their VDM module.
Re: LED's?
rimai wrote:I guess I just found out the answer of the inverted signal.
Once you had mentioned it being RS-232, this also made sense
http://www.ghl-direct.com/proddetail.ph ... profiluxAI
Re: LED's?
So, I went to LFS today to measure the voltage and took an RA with me with the inverted UART signal.
I guess there is no need for additional hardware
This was my very crude attempt of thunderstorm, just to confirm that I could control it.
[youtube]http://www.youtube.com/watch?v=gDniy7FvF0A[/youtube]
So, I guess I'll work on creating a library for it and have some cables available at the webstore very shortly
Re: LED's?
awesome, let me know when the cables are ready
Re: LED's?
I see the class added to Curt's github. I am excited to get this working
Re: LED's?
Has anyone else built one of these? I have the shielding going to the base of the plug and red wire going to middle section, with my polarity same as the dimmer ports on relay.. But its still not contrilling my ai sol.
Re: LED's?
Anyone? All i seem to get is full on or a flicker with my sol
