cant refresh memory on Client
Bogdan
Post by Bogdan »
After upgrading to new RA 1.0.7 and library 1.0.7 and Client 3.0 I cant refresh the memory it gives me the message:Unable to retrieve controller memory settings.
I tried to download the RAMemory as suggested below, but it didn't help.
Download the RAMemory.ini file attached to this post and save to your PC. From the Client, choose Settings => Load Memory File and browse to the file you just downloaded. You should get a success message. Restart the Client and try refreshing the memory tab once more.
-Dave
RAMemory.ini
Updated Memory Map
(3.22 KiB) Downloaded 60 times
I need this change the standard pH values.
Please advise how can I fix it.
Re: cant refresh memory on Client
