Need help with MacBook....
rweber504
Post by rweber504 »
Hello....Can anyone for the life of me can tell me why my MacBook 10.6.8 does not work with my ReefAngel controller?
Everytime I try to upload a simple file it says "error=86, Bad CPU type in executable
at java.lang.ProcessBuilder.start
at java.lang.Runtime exec(Runtime.java.593)
at java.lang.Runtime exec(Runtime.java.466)"
I was lucky enough to get it to work with my RA wi-fi module when it had to be reprogrammed. Other than that ,no luck.
I've had friends come over with their PC computers to program my RA controller with no problem. Please, any ideas are welcome! I'm Begging!!!
Randy :?:
dbmet
Re: Need help with MacBook....
Post by dbmet »
What processor do you have in your mac? Have you tried this thread?
http://forum.reefangel.com/viewtopic.php?t=2987
rweber504
Post by rweber504 »
Thanks I'll check it out...cause I'm really trying to like this controller! I also have an issue where my WiFi lite is flashing green but my Iphone RA app is not responding. What gives?
Are you using the correct IP address in the iphone app? Do you also have direct mode turned on?
rweber504 wrote:Thanks I'll check it out...cause I'm really trying to like this controller! I also have an issue where my WiFi lite is flashing green but my Iphone RA app is not responding. What gives?
Learning curve. It'll pay off. Trust me :)
dbmet
Post by dbmet »
What IP address are you using on your iPhone? Did you check to make sure port 2000 is forwarded to your reef angel
rweber504
Post by rweber504 »
Yeah, port forward is 2000, IP is correct...I changed Internet services from Cox to optic fiber LUS services. Maybe I need to check my router settings?
