I am a total noob at my RA but I got everything running as Im using it just for basic things, but the only problem I ran into is that my RA uses my only temp probe to check of overheat. Is it possible for the controller to use a single temp probe to control my heater and check for the overheat? or /will I have to purchase extra temp probes? thank you guys for your help
temp probe question :)
tomek77pl
hi guys,
- cosmith71
Re: temp probe question :)
One probe can do both. Are you not getting a temp reading?
Sent from my HTC One X using Tapatalk 2
tomek77pl
yes I am but my temp socket wont turn on
- cosmith71
Can you post your code?
tomek77pl
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port1,600,778 );
ReefAngel.DosingPumpRepeat( Port6,0,50,15 );
ReefAngel.StandardLights( Port7,0,0,10,0 );
ReefAngel.SingleATO( true,Port8,10,0 );
- cosmith71
By this, your heater should come on at anything less than 60 degrees F, Shut off at 77.8 degrees F, and overheat at 80 degrees, shutting off ports 1, 3, 5, and 7. What's your current temp? Is the red light on?
tomek77pl
my current temp is 77.9 but when I take the temp probe out and the temp drops util 75.5 the socket will still not turn on, its red which indicates its shut off.
- cosmith71
Is the red LED on the front of the head unit on?
- cosmith71
Oh, it won't come on until it hits 60 degrees as its programmed now.
tomek77pl
I got it to work when I changed the temp from 60F to 70F. I want the heater to turn on when ever it is under 77.8, so my code would look like this for the heater? ( Port1,778,778 )?
- cosmith71
So something like this:
ReefAngel.StandardHeater ( Port1,778,782 );--Colin
Edit: Changed the temps a bit.
tomek77pl
thank you for your help, I set it to (Port1,788,788) . The wizard is where I got confused I tried setting the lowest temp so I would turn on when ever it was not 78.8F
- lnevo
You really dont want the parameters equal. Its going to continuously cycle the relay on and off like that.
I would suggest setting the low/on temp to 76 or something and the high you can leave as is.
You want the heater on for a set amount of time to heat the water. You will probably damage your heater and eventually the relay the way you have it...
tomek77pl
thank you for the advice I switched it back to 760,778
