wifi adapter wont Sync with RA client
tomek77pl
Post by tomek77pl »
Hi
I recently purchased a wifi expansion and I got everything to work with the portal and my iphone but I cannot figure out how to connect the reef angel client suite to my wifi adapter. Am I missing a something in my code? because everything in the RA client settings is set correctly. thank you for your help :)
Here is my code:
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port1,773,778 );
ReefAngel.DosingPumpRepeat( Port6,0,50,15 );
ReefAngel.StandardLights( Port7,23,0,10,0 );
ReefAngel.SingleATO( true,Port8,10,0 );
ReefAngel.Portal( "tomek77pl" );
I also get this error message :
*****6/15/2013 8:23:34 PM*****
Message:
Inside WifiSend:
Unable to connect to the remote server
StackTrace:
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadString(Uri address)
at System.Net.WebClient.DownloadString(String address)
at ReefAngelWCFListener.ReefAngelListener.WifiSend()
Re: wifi adapter wont Sync with RA client
Your code looks fine.
Make sure that you have it set to connect over wifi and that you have the correct url.
tomek77pl
Post by tomek77pl »
The client mentions that it can not complete a web-request call to the wifi adapter. what could cause this? I have set all the right addresses to the portal. but when I access my portal it says that my connection status: Unreachable address. is that normal?
dbmet
Post by dbmet »
Is your port forwarding turned on in your router for port 2000?
tomek77pl
Post by tomek77pl »
Got it to work, it was the port forwarding, thank you so much :)
dbmet
Post by dbmet »
Great!!
tomek77pl
Post by tomek77pl »
I still get an error message from the wifi Icon that says Could not complete the web request call to wifi adapter & when I set up my notifications for low PH I get email and texts every hr saying my ph is 6.84 when on the Reef Client, Portal and on the controller it self I have my ph around 7.89. I have calibrated the probe yesterday as well.
