Do you have some problem with the salinity probe?
Can I change the salinity for density? (example: 1.025)
Salinity Probe
Re: Salinity Probe
Salinity varies with temperature. If you assume temperature is constant, you can mathematically convert one to another.
Re: Salinity Probe
Can I do a code to have this alternative?
Re: Salinity Probe
Isn't the compensation part already done?
http://forum.reefangel.com/viewtopic.php?f=3&t=2670
Wouldn't it just be a matter of mapping the values now?
Re: Salinity Probe
Even though the compensation is there, it hasn't been much used to confirm that it really does its job.
But yeah, you can assume it would be compensated or constant and then map values.
Re: Salinity Probe
i have been using it in a cup of water for testing. i think i had it calibrated a little high but it has appeared to work. I need to hook it up to my tank and watch it for certain though. hopefully i can get it connected tomorrow and see how it works.rimai wrote:Even though the compensation is there, it hasn't been much used to confirm that it really does its job.
Sent from my Nexus 7
