alright i replaced what you said to... we will see if that works, i have them going into containers of their own to see if it works come the morning...lnevo wrote:In place of the lines where your other dosingpump lined are...
dosing pumps
Re: dosing pumps
Re: dosing pumps
well i believe that inserting that code worked as there was liquid in the containers when i checked them...
what is the portal interval for recording input? the portal still doesnt show that the relays were activated when they were...
Re: dosing pumps
The portal wont show it. 10 seconds is not enough time. It only logs every 5 minutes.
Re: dosing pumps
If you look through this thread http://forum.reefangel.com/viewtopic.php?f=12&t=3262 you can see what I did for kirkwood. There's some code I wrote for myself to switch to volume based dosing instead of time so it does all the calculations and also the code that was specific for kirkwood that logs the amount of time the dosers are on and logs it to the portal so he can track how much time exactly the pumps are on. I can help you implement it for yours if your interested.
