I see that Avast Marine ATO comes with the digital Reefangel plug. Has anyone used this?
http://www.avastmarine.com/ssc/do/produ ... op-off-Kit
Avast ATO
Re: Avast ATO
Im using the ra attachment for their skimmate locker. Works great. However i think you're better off with the multi level pressure sensor. You'll be able to read it more precisely and you can monitor 5 different water levels... But the avast will just act like a float switch.
Re: Avast ATO
Thanks Inevo, Does RA sell this multi level pressure sensor? If not which one are you using, any link?
I've been reading the thread "New ATO pressure switch-setup with Wizard?" and I'm trying to figure out which sensor would be best to use.
Re: Avast ATO
Send rimai a PM. Not sure if its for sale yet, but i believe there may be some avail..
Re: Avast ATO
It's this one:
http://forum.reefangel.com/viewtopic.php?f=3&t=3605
But I don't have any more of those at the moment.
Only the single level is available and can be purchased in the webstore.
Re: Avast ATO
thanks Roberto, I probably wait for official release of multi then. I saw you said few weeks in another thread, so I will hold off until then. Hope it passes tests. What's is look like for cost? Love to see one running/test in a video
Re: Avast ATO
There are a couple people using them already.
It works just like the single channel that is already available.
