Power outage alert
- jsclownfish
Re: Power outage alert
So would I have to make a junction between the serial connection or can the master controller feed off the slave if there was a battery set connected to the 5v/gnd lines?
The master could feed off of the slave, but it is really not designed for that.
The best option I see is to use a small UPC. It will maintain RA long enough for your email alert.
- jsclownfish
Makes sense. I'll just get something like this....http://www.amazon.com/CyberPower-CP425S ... 60&sr=1-17. I was just thinking about the options and a small battery pack is really inexpensive.
-Jon
-Jon
Any suggestions on how to hook up to a APC battery back up system? I currently have one on both my PC, router and another on the tank. There are 4 outlets (out of 8) on the UPS that are battery backed up. Here is what I am thinking...
-use one of the non-battery backed outlets with the suggested wall wart to indicate loss of power.
-use one battery backed outlet for the RA
-use one battery backed outlet to plug the relay box into
-program the ATO port used to indicate the loss of power, to shut down everything except the return and skimmer (for oxygenation).
Yes, that would work great!!
Just make sure not to feed more than 5VDC into the ATO port.
What kind of wall wart would you suggest? I tried looking a few up but have no idea which one to get or how I would connect it to the pwm port. I would like to integrate this into my controller as well. Do you think this kind of thing might be useful to provide on your guys' online store?
You can use any regulated 5VDC walwart. The best ones are the ones made for cell phones and have a USB plug in it. USB uses 5VDC as standard.
Get a good quality one or you will end up frying the controller. I've seen them output more than 5VDC.
What about a 3vdc supply? You said not more than 5vdc, so what is the LO threshold that indicates loss of power?
You are very right about the 5Vdc wall warts, I checked several and they were all off. Most were in the 7vdc range. One of my 12vdc supplies was actually at 17vdc!
Found a usb charger like you described for an old blackberry. Says 5V output @ 700mA, I'll verify the 5V with a multimeter but assuming its accurate this should work? If both my ATO ports are in use can I use any of the ports on the relay box?
Okay, tested out the adapter and it seems to put out around 4.95-5.17 VDC. I'm assuming this will be okay to hookup using my ATO High switch port? That said, could you give an example of code I test if power did fail? For example, I would like it to deactivate port 1 and 2 on the main relay box along with port 3 and 4 on the relay expansion box. Once power is restored I would then like to enable the disabled relays. Thanks in advance!
Try this.
On setup():
Your loop() need to look like this:
ShowInterface() has to be the last line and the check has to be right above it.
On setup():
digitalWrite(highATOPin,LOW);
// Your code goes above here
if (!digitalRead(highATOPin))
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.Off(Port2);
ReefAngel.Relay.Off(Box1_Port3);
ReefAngel.Relay.Off(Box1_Port4);
So it looks like I shorted the ATO high port out.
I made sure to connect up the adapter with the correct +/- sides using indications on the existing ATO switch cables. When I hooked up the adapter to the ATO high port my tank lights flashed on and the red status light started blinking. I shut off the adapter (I had it plugged into a surge strip for easy on/off).
Now the ATO high port indicates there's no power going to it, even though the float switch is all the way down. Just to make sure it wasn't the actual float switch, I hooked up the other one and got the same indication. I went ahead and modified my ATO code so that it will at least top the tank off, as I was using the ATO high as a safety in case the pump or something malfunctioned. But I had to take that out, since it registers as open instead of closed keeping the ATO pump from engaging.
Thought I was doing everything right...
Do you still have this on the setup()?
If so, you are disabling the port for use as ATO as it is actually using pull-down instead of pull-up.
No, I reverted back to my old code to make sure it wasn't something that I had done since. Also the RA Client shows the ATO Hi as red, normally it's green since the switch is all the way down making contact.
Here's my code just in case:
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define Daylight 1
#define AutoTopOff 2
#define Heater 3
#define Return 4
#define WavemakerL 5
#define WavemakerR 6
#define LEDs 7
#define Refugium 8
#define AlkDoser 13
#define CaDoser 14
#define AclHeater 17
#define GFO 18
randomSeed(analogRead(0)); //wm stuff
ReefAngel.FeedingModePorts = B00111000;
// ReefAngel.WaterChangePorts = B00000000;
// ReefAngel.OverheatShutoffPorts = B00000101;
// ReefAngel.LightsOnPorts = B00000001;
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(GFO);
//WaveMaker stuff
ReefAngel.Timer[1].SetInterval(random(15,35));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(WavemakerL);
// ReefAngel.StandardFan(Chiller,775,783); Removed for ATO function
// ReefAngel.StandardHeater(Heater,785,79);
ReefAngel.StandardLights(Daylight,10,0,21,00); //Daylight schedule 10:00am - 9:00pm
ReefAngel.StandardLights(Refugium,21,0,10,0); //Refugium schedule 9:00pm - 10:00am
ReefAngel.StandardLights(LEDs,9,00,22,00); //LED schedule 9:00am - 10:00pm
ATOFailSafe(AutoTopOff); //ATO Stuff
//Heater Temp Settings
// Turn on Heaters when the temp < 78.8 degrees
if ( ReefAngel.Params.Temp1 < 788 ) ReefAngel.Relay.DelayedOn(Heater, 1);
// Turn off Heaters when the temp > 78.6 degrees
if ( ReefAngel.Params.Temp1 >= 791 ) ReefAngel.Relay.Off(Heater);
//Acclimation Heater Temp 2 settings
// Turn on AclHeater when the temp < 78.8 degrees
if ( ReefAngel.Params.Temp2 < 788 ) ReefAngel.Relay.DelayedOn(AclHeater, 1);
// Turn off AclHeater when the temp > 79.1 degrees
if ( ReefAngel.Params.Temp2 >= 791 ) ReefAngel.Relay.Off(AclHeater);
//Wavemaker
ReefAngel.Timer[1].SetInterval(random(15,30));
ReefAngel.Relay.Toggle(WavemakerL); //port 5
ReefAngel.Relay.Toggle(WavemakerR); //port 6
//Dose Ca
if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Ca Doser - Only works if Main screen is showing
/* && = and || = or
Hours between 12am and 8am
minute must be 0 (top of the hour)
seconds less than 2 (up to 2 seconds)
if ( ((hour() >= 0) && (hour() <= 8)) && (minute() == 0) && //dose time
(second() < 2) ) //dose duration
ReefAngel.Relay.On(CaDoser);
ReefAngel.Relay.Off(CaDoser);
//Dose Alk
if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Alk Doser - Only works if Main screen is showing
/* && = and || = or
Hours between 12:05am and 8:05am
if ( ((hour() >= 0) && (hour() <= 8)) && (minute() == 5) && //dose time
ReefAngel.Relay.On(AlkDoser);
ReefAngel.Relay.Off(AlkDoser);
void ATOFailSafe(byte ATO) //changed port to fATO
// Check for the low switch
If the Low switch is active, meaning the float is opposite the end with the two wires,
we are empty so we should turn on the pump. Otherwise, we are full, so turn off the port.
if ( ReefAngel.LowATO.IsActive() )
ReefAngel.LowATO.StartTopping();
ReefAngel.Relay.On(ATO);
ReefAngel.LowATO.StopTopping();
ReefAngel.Relay.Off(ATO);
PM me if you want to replace.
I went back and read what you wrote and I think the confusion was on the part where you followed the markings on the ATO cable.
The ATO float switches use the same pinout as the PWM output ports.
You can find the pinout in the user manual.
Okay, yeah that's def it I'll shoot you a PM.
How about a 5v supply that outputs 30v...
My poor ReefAngel... she didn't deserve that. She didn't do anything to anyone.
wallwarts...
Shout out to the creator of our angels... he takes good care of them. Roberto, this next drink is for you.
PM Sentrimai wrote:PM me if you want to replace.
- jsclownfish
I'm wondering, what do you leave on "life support" in case of a power outage and a switch to battery power. I'm thinking that it may not be much more than the RA unit, relay box, & power heads in the tank for circulation as they draw very little power.
-Jon
-Jon
- jsclownfish
I'm curious if there is a better way to monitor for power. I have it set up on the IO expansion and if it changes from high to low, then the power to most of the relays is turned off. The problem (atleast I think it may be a problem) is that if anything breaks down the connection across the I2C communication, then the system essentially goes into shut down thinking the power feed has dropped. Any thoughts?
Jon
Jon
- jsclownfish
I suppose that would be the best way to get around the issue. I didn't do that initailly because I'd then have to code in the logic for the standard ATO if one of them (low or high) was coming from the IO expansion instead of using the ReefAngel.StandardATO function.
-Jon
-Jon
- jsclownfish
Looking at the StandardATO code a bit in the library, will this work if I receive a signal from the IO expansion for the LowATO? I figure it is best to use that one in case of a communication error as I would rather the sump go low than to overflow.
Jon
Jon
//Set the Low ATO to the IO device, receive IOLowATO = 1 or 0
byte IOLowATO = 0;
//Temp timeout
unsigned long TempTimeout = ATOTimeout;
TempTimeout *= 1000;
Is the low switch active (meaning we need to top off) and are we not currently topping off
Then we set the timer to be now and start the topping pump
if (IOLowATO == 1)
ReefAngel.LowATO.Timer = millis();
ReefAngel.Relay.On(Box1_Port1); //ATO pump on Box1 Port 1
// If the high switch is activated
if ( ReefAngel.HighATO.IsActive() )
ReefAngel.Relay.Off(Box1_Port1);
If the current time minus the start time of the ATO pump is greater than the specified timeout value
AND the ATO pump is currently running:
We turn on the status LED and shut off the ATO pump
This prevents the ATO pump from contniously running.
if ( (millis()-LowATO.Timer > TempTimeout) && IOLowATO==1 )
ReefAngel.LED.On();
- jsclownfish
Maybe I oversimplified trying to limit the post. It would be broken up like this. The status of the lowATO should come from the I/O..
byte IOLowATO = 0;
//Temp timeout
GetFlow();
if (IOLowATO == 1)
ReefAngel.LED.On();
void GetFlow()
Wire.requestFrom(7,8);
if(Wire.available())
for (int a=0;a<10;a++)
IOIn[a]=Wire.read();
Flow0=(IOIn[1]<<8)+IOIn[2];
Flow1=(IOIn[3]<<8)+IOIn[4];
Power=IOIn[5];
Overflow=IOIn[6];
Reservoir=IOIn[7];
How did this turn out? I am very interested in this.
