Salinity Probe
ecam
Salinity Probe
Post by ecam »
Hello All,
I've been struggling with my salinity probe for that last few weeks. I calibrated using my tank water that is always at 35.0 as per two refractometers that I have. The problem is that when I calibrate it will hold for a week or so and then start to drift. (right now it is showing 31.6) My refractometer hasn't moved from 35.0 (i tested several water sources and the refractometer is accurate). I am about to setup top off based on salinity reading but cant really trust the probe. Can someone please advise on the best way to fix this problem.
Albe
Re: Salinity Probe
Post by Albe »
Have you checked for stray electricity in your tank? It could also be micobubbles getting caught at the bottom of the probe, if you give it a shake does the the values change?
Re: Salinity Probe
If you put the probe in a cup of tank water what does it read?
ecam
Re: Salinity Probe
Post by ecam »
The reading stays the same... but the refractometer confirms my 35.00
No stray voltage from what i can tell
Re: Salinity Probe
Sounds like a bad probe...i know there were a few cases like this. Not sure what happened to address. I think Sacohen had the same issue.
