Dosing Calcium and Alkalinity
SEANTADEZ
Post by SEANTADEZ »
Hello guys i'm new here... another wamas member, i just have a silly question about my dosing pumps:
Before, i was using a timer schedule to add during the day the calcium and at nights the alkalinity solution, now i got my RA Controller and I'm not familiar with the code yet, my question is, the wizard allow me to set every 60 min dosing for X sec, is that fine if i dose alk and calcium every hour with 30 min delay in one? or should i try to build a code to go back to my old schedule of day and night dosing?
any comments? Help with code?
Re: Dosing Calcium and Alkalinity
The RA defaults will dose hourly with a 5 minute delay between each dosing pump. For ease of use I would say stick with that...
However, being that this is the ReefAngel and you shoudl be able to do whatever you want to do :)
What I would do is set the dosing pumps to dose the appropriate amount you want. Then use similar code below to override this to meet your needs...
Let's say Port 1 is your Calcium and Port 2 is your Alk. You have them set in the portal or in your code to dose for X seconds. You want Port 1 to only dose during the day and Port 2 to dose only at night.
So...
if (hour() >= 8) && (hour() < 20) { // Between 8am and 8pm we will disable Port 2
  ReefAngel.Relay.Off(Port2);
} else { // At night we'll disable Port1
  ReefAngel.Relay.Off(Port1);
SEANTADEZ
Post by SEANTADEZ »
great, so what i need to do is calculate the ml that can be dose in 12 hours to keep my level of dose and paste this code to split the dose (cal-Day, all-night) right?
SEANTADEZ
Post by SEANTADEZ »
I got this error:
Watchdog Timer
Version Menu
2014 Main Screen
Standard Menu
basico_inicial.cpp: In function 'void setup()':
basico_inicial:67: error: expected identifier before '(' token
basico_inicial:67: error: expected `;' before '(' token
basico_inicial:78: error: a function-definition is not allowed here before '{' token
basico_inicial:92: error: expected `}' at end of input
Is there anything i should add before paste the code? I'm missing something else?
BTW thanks a lot for your help
SEANTADEZ
Post by SEANTADEZ »
this is the whole code:
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.DosingPumpRepeat( Port1,00,60,10 );
ReefAngel.DosingPumpRepeat( Port2,0,60,10 );
ReefAngel.StandardHeater( Port7,780,795 );
ReefAngel.StandardLights( Port8,22,0,8,0 );
SEANTADEZ
Post by SEANTADEZ »
I was trying to add the code that you post for someone else about clear the overheat function and i got error too...
Sorry, I made some mistakes in the parenthesis
if ((hour() >= 8) && (hour() < 20)) { // Between 8am and 8pm we will disable Port 2
SEANTADEZ
Post by SEANTADEZ »
lnevo wrote:Sorry, I made some mistakes in the parenthesis
Awesome that works great...
I really appreciate it...
