Day night mode for wave maker
PostPosted: Sat Apr 05, 2014 8:15 am
Hi there,
I want to let my wave maker go slower at night.
Is there any coding that can let it flow normaly during the day and slower at night?
Thank you in advance.
PostPosted: Sat Apr 05, 2014 8:21 am
I'm assuming you are talking about Jebao, right?
Can you post your code?
PostPosted: Sat Apr 05, 2014 12:22 pm
Hi Roberto,
Yes i am.
I'm looking for the code. Hehe 8-)
PostPosted: Mon Apr 14, 2014 9:29 am
rimai wrote:I'm assuming you are talking about Jebao, right?
ReefAngel.FeedingModePorts = Port2Bit | Port3Bit | Port5Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.CustomLabels[1]="Wave Maker";
ReefAngel.CustomLabels[2]="Skimmer";
ReefAngel.CustomLabels[3]="Reactor";
ReefAngel.CustomLabels[4]="ATO";
ReefAngel.CustomLabels[5]="Lights";
ReefAngel.CustomLabels[6]="Chiller";
ReefAngel.CustomLabels[7]="ReturnPump";
ReefAngel.StandardHeater( Port1,265,270 );
ReefAngel.Relay.DelayedOn( Port3,4 );
ReefAngel.SingleATO( true,Port5,60,0 );
ReefAngel.StandardFan( Port7,270,275 );
ReefAngel.DCPump.SetMode( ShortPulse,40,40 );
ReefAngel.Portal( "Ferdi" );
PostPosted: Mon Apr 14, 2014 5:11 pm
Try this:
  if (hour()>=8 && hour()<18) // Day mode between 8am and 6pm
    ReefAngel.DCPump.SetMode( Constant,30,0 );
PostPosted: Tue Apr 15, 2014 10:40 am
Thank you Roberto. Works perfectly
PostPosted: Sat Jul 30, 2016 12:15 am
With this code can you adjust the wave makers from the portal or is it just hard coded?
I would like to have night mode and day mode with Jeboa wave makers.
Is someone able to post code on how this is done. Thanks
PostPosted: Sat Jul 30, 2016 3:26 pm
This is hard coded. The best way to do this is to wrape the whole section that is setting the different modes with an if that checks the mode setting in memory and only runs the schedule if the mode is Custom. If not it will use settings in memory.
Return to Ask anything here
