Day night mode for wave maker
Posted: Sat Apr 05, 2014 8:15 am
by Ferdi
Hi there,
I want to let my wave maker go slower at night.
Is there any coding that can let it flow normaly during the day and slower at night?
Thank you in advance.
Re: Day night mode for wave maker
Posted: Sat Apr 05, 2014 8:21 am
I'm assuming you are talking about Jebao, right?
Can you post your code?
Posted: Sat Apr 05, 2014 12:22 pm
by Ferdi
Hi Roberto,
Yes i am.
I'm looking for the code. Hehe 8-)
Posted: Mon Apr 14, 2014 9:29 am
by Ferdi
rimai wrote:I'm assuming you are talking about Jebao, right?
ReefAngel.FeedingModePorts = Port2Bit | Port3Bit | Port5Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.CustomLabels[0]="Heater";
ReefAngel.CustomLabels[1]="Wave Maker";
ReefAngel.CustomLabels[2]="Skimmer";
ReefAngel.CustomLabels[3]="Reactor";
ReefAngel.CustomLabels[4]="ATO";
ReefAngel.CustomLabels[5]="Lights";
ReefAngel.CustomLabels[6]="Chiller";
ReefAngel.CustomLabels[7]="ReturnPump";
ReefAngel.StandardHeater( Port1,265,270 );
ReefAngel.Relay.DelayedOn( Port3,4 );
ReefAngel.SingleATO( true,Port5,60,0 );
ReefAngel.StandardFan( Port7,270,275 );
ReefAngel.DCPump.SetMode( ShortPulse,40,40 );
ReefAngel.Portal( "Ferdi" );
Posted: Mon Apr 14, 2014 5:11 pm
Try this:
  if (hour()>=8 && hour()<18) // Day mode between 8am and 6pm
    ReefAngel.DCPump.SetMode( Constant,30,0 );
Posted: Tue Apr 15, 2014 10:40 am
by Ferdi
Thank you Roberto. Works perfectly
Posted: Sat Jul 30, 2016 12:15 am
by GreenVF
With this code can you adjust the wave makers from the portal or is it just hard coded?
I would like to have night mode and day mode with Jeboa wave makers.
Is someone able to post code on how this is done. Thanks
Posted: Sat Jul 30, 2016 3:26 pm
This is hard coded. The best way to do this is to wrape the whole section that is setting the different modes with an if that checks the mode setting in memory and only runs the schedule if the mode is Custom. If not it will use settings in memory.
