Now what do I do?
Clueless Noob!!
Re: Clueless Noob!!
Please Guys! Still need help Here? Everything is setup so far! The Wifi works thru my home network when I use my iPhone but cant access it thru the internet!'
Re: Clueless Noob!!
Any Takers on some Help?
Re: Clueless Noob!!
What is your model number? Should be on a sticker somewhere on the router.
Re: Clueless Noob!!
You just need to create a rule to allow port 2000 to connect to the ip address of the reefangel. There should be a form to add a new rule. Post some screenshots if your that stuck.
Re: Clueless Noob!!
Also, try this:
www.simpleportforwarding.com
I think is some sort of key press generator that presses the right keys for you. I've heard from other users that it works.
