heaters
heaters
hi just joined the forum, not yet received my reef angel, just a quick question can I set up a backup heater on may reef angel? I have two aqua medic titanium heaters thanks for your help.
Re: heaters
well set one to run the tank, and to use the other heater as a failsafe, maybe set at a lower temperature than the main heater. you see I have never had a reef controller before, I am currently running heaters with there own thermostats I have just bought my aqua medic heaters to run on the reef angel many thanks.
Re: heaters
I would save your relays and plug both heaters into one relay. Set it as a StandardHeater and program your on and off temp. Then on the heaters you could put one with a temp a bit higher and one a bit lower.
- jsclownfish
Re: heaters
I do something similar.... Back-up Heater http://forum.reefangel.com/viewtopic.php?t=412
- maineultraclassic
Re: heaters
I always run 2 heaters, if one dies you always have the other one to at least try and keep things warm.
54gal Corner Bowfront with 30gal basement sump
