Stuggling with the LDD Drivers
newtoke
Post by newtoke »
I just can't get them to work. Only one driver, will turn on the lights when I unplug them from the PWM connections on the relay box. How can I test to see if the LDD drivers are the issue (I do get 48 volts from it). Or if the signal is really analog out of the relay box.
Re: Stuggling with the LDD Drivers
Not sure where you got your information, but LDD drivers are a little different than other drivers.
Check the datasheet:
http://www.meanwell.com/search/LDD-H/LDD-H-spec.pdf
They don't work with analog signals. They work with 0-5V PWM dimming.
The relay boxes output 0-10V signals. According to the datasheet, the max voltage is 6V. So, I'm not sure if the input dimming channel of your drivers got burned out or not.
How new is your dimming module?
The newer models have jumpers in them that you can change each channel from analog to PWM to from 0-10 to 0-5v.
Although Roberto is correct you may have fried the input dimming channel of your drivers.
Try feeding a 0-5v PWM signal into it (if you have that option) and see what happens.
newtoke
Post by newtoke »
rimai wrote:Not sure where you got your information, but LDD drivers are a little different than other drivers.
*** URL Removed ***
I thought the relay box either outputted a PWM or Dimmer signal and I thought I bought the one with the pwm signal. (There isn't a sticker saying dimmer on the bottom). Are you saying the PWM signal out of the relay box is a 10 volt signal and not 5?
newtoke
Post by newtoke »
Sacohen wrote:How new is your dimming module?
Feed a 5v PWM signal? How? Where can I buy a 5 volt PWM feeder/ generator? I looked all over the internet for one and couldn't anything except for Ebay, but none of them guaranteed a 5 volt signal
I thought you had the dimming module and weren't using the dimming ports on the relay. Yes the signal out if the relay box us 0-10v regardless of if you got the PWM or analog.
I think there is a sticker inside if I remember correctly.
If your relay is PWM, but 0*10v you can code it to not go about 50%.
newtoke
Post by newtoke »
How do you code it to go 50%? And I assume you mean voltage 50% and not PWM signal 50%. Roberto is this true? If so, cool. If not, I'd rather not buy a PWM dimming module, so is it possible to build and interface/ converter?
The PWM control signal going from the RA dimming ports to PWM in on the LDD would be 50% of the full 10v (or 5v).
Here is code for a PWM slope going from 0-50% for the daylight and actinic channels.
Times are 9am to 8pm.
    ReefAngel.PWM.SetDaylight( PWMSlope(9,0,20,0,0,50,60,0) );
    ReefAngel.PWM.SetActinic( PWMSlope(9,0,20,0,0,50,60,0) );
newtoke
Post by newtoke »
Sacohen wrote:The PWM control signal going from the RA dimming ports to PWM in on the LDD would be 50% of the full 10v (or 5v).
I respect your thoughts on this Steve, but as I understand what PWM is and as referenced in the following post from Roberto...
http://forum.reefangel.com/viewtopic.php?f=2&t=2980
I don't think this is correct. A PWM determines the value between the width of each pulse, it still pulses at 10 volts right?
newtoke wrote: I respect your thoughts on this Steve, but as I understand what PWM is and as referenced in the following post from Roberto...
Correct.
PWM will output a 0-10V PWM signal and will change the width of the pulse.
The new dimming expansion modules can outpout 0-5V PWM signals.
newtoke
Post by newtoke »
Correct.
Thanks Roberto... So there is no way to get the PWM signal out of the relay box to be 5 vdc?
Technically there is, but it will require you to open the box and solder some jumper bridges with wires to short out the gain of the op amp that boosts the signal.
Another way is to use your ATO port. They output 0-5V PWM.
Something like this:
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,2.55*80); // set Low ATO port to 80%
Sorry you are correct. I was thinking backwards. My brain is a little foggy right now, I've been up all night the past 2 nights working on a freelance video editing job.
newtoke
Post by newtoke »
rimai wrote:Technically there is, but it will require you to open the box and solder some jumper bridges with wires to short out the gain of the op amp that boosts the signal.
When I set the pin mode, do I just set it in Setup and the analogWrite in the loop? Also I assume the RA libraries won't freak out over the ATO been used as a output instead of input correct?
No, you need to have it on loop too.
People have used this for Jebao pumps, but nobody has never tested with LEDs.
newtoke
Post by newtoke »
Is it true that only one ATO port can send out PWM?
Also what configuration have folks had success with?
On the standard RA, only one, but on the RA+, you can use both.
newtoke
Post by newtoke »
Sigh... it didn't seem to work. I put those two lines you mentioned before the "interface" method. This is what I did:
//ATO PWM output
  pinMode(lowATOPin, OUTPUT);
  pinMode(highATOPin, OUTPUT);
  analogWrite(lowATOPin, ReefAngel.PWM.GetActinicValue() * 2.55);
  analogWrite(highATOPin, ReefAngel.PWM.GetDaylightValue() * 2.55);
  ReefAngel.Portal();
I am ordering new drivers in case I fried them. Any other ideas? I'd really love to find a testing device that can generate a PWM signal and a device that can test a PWM signal, but I have yet to find any.
What size LDD do you need.
I think I have 2 1000mA that I'm not using.
newtoke
Post by newtoke »
I already ordered two 1000ma Steve... Thanks for the offer. I ordered the PWM Expansion Module, because it appears that is the only way people are having success... I would though hope that Roberto will add the ability to modify the voltage out of the relay pack PWM outputs in the future.
No Problem. Good luck with them.
I have 4 that I need to get motivated to set up.
newtoke
Post by newtoke »
newtoke wrote:Sigh... it didn't seem to work. I put those two lines you mentioned before the "interface" method. This is what I did:
//ATO PWM output
  ReefAngel.Portal();
Roberto any thoughts on this code?
Code looks fine.
Sent from my SM-G900P using Tapatalk
newtoke
Post by newtoke »
Doesn't work... Only thing that happens is that the lights go out. Hopefully the dimmer module I just purchased will solve this?
blert
Post by blert »
newtoke wrote:Sigh... it didn't seem to work. ...
The LDD drivers and the controlling device MUST share a common ground. You can't just send them a signal and have them work, they need to be properly hooked up electrically.
newtoke
Post by newtoke »
I know the ground from the RA ATO port was connected to the -Vout on the power supply. I was trying to use Roberto's suggestion of having using the ATO as a PWM 5vdc signal using the code shown in earlier in this thread, but the lights would just stay dark.
Do you get any voltage when you measure the ago ports?
newtoke
Post by newtoke »
I went ahead and purchased the Dimmer module. I opened it up and put in the 5 vdc jumpers. I wired ther LDD white wire to the dimmer and the negative or ground of the DImmer module to the negative VOut on the power supply and the lights don't turn on at all.
If I disconnect the white wire from the dimmer module then I get 100% full on from my lights
Did you change your code to use the dimming expansion module?
Can we see it?
