Avast ATO and RA+
PostPosted: Wed May 28, 2014 5:17 pm
I upgraded my head unit to the RA+ and it was either then or shortly after my avast ato stopped working. Is there anything in the new libraries that could be doing this or did my ato just die for some reason? (Pump still works, but nothing will make the trigger unit trigger).
PostPosted: Wed May 28, 2014 5:25 pm
Isn't Avast ATO a standalone?
Or you have their controllable with the adapter cable?
PostPosted: Wed May 28, 2014 5:27 pm
Controllable with the adapter cable.
PostPosted: Wed May 28, 2014 5:37 pm
Test the ATO port with the controllertest code
PostPosted: Wed May 28, 2014 7:17 pm
I have no idea how to do that, sorry =X Can you explain or point me towards a thread?
PostPosted: Thu May 29, 2014 8:13 am
File->Sketchbook->Example Codes->ControllerTester
Upload and test the ports.
PostPosted: Sun Jun 01, 2014 5:53 pm
So I uploaded the code. ATO showed high and low as OPEN. I pulled the ATO probe thing out of the water and it still showed as open. So I am thinking I need to buy a new ATO.
PostPosted: Sun Jun 01, 2014 8:19 pm
Just to confirm, before you go buying anything...
Can you unplug the avast ato connector from RA and use a regular float switch?
PostPosted: Wed Jun 04, 2014 6:51 pm
I assume you were concerned it might be the head unit? I got out my original float switches and plugged them in and it all worked fine. So it seems it is something with the Avast unit or plug.
PostPosted: Thu Jun 12, 2014 4:15 pm
I got my new ATO switch from AVAST. However I still cannot get it to trigger! Here is a copy of my code, please let me know if you see anything wrong here. I am going to run another controller test to double check things. (I am not too great with the coding yet so something might be wrong that I never noticed)
    ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    InternalMemory.OverheatTemp_write( 810 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardLights( Port1,13,30,22,30 ); //set for actinic
    ReefAngel.SingleATO( false,Port2,900,0 ); //15 min time out
    ReefAngel.StandardLights( Port4,14,0,22,0 ); //set for white light
    //removed wavemaker functions because I don't want them turning off
    ReefAngel.StandardHeater( Port7,775,780 );
    ReefAngel.PWM.SetDaylight( PWMSlope(13,30,22,0,15,100,30,15) );
    //ReefAngel.PWM.SetActinic( PWMParabola(13,0,22,30,15,100,15) );
    // prevent auto top off from 2200 to 1200
    if (hour()>12 && hour()<22)
      ReefAngel.SingleATO( false,Port2,600,0 );
      ReefAngel.Relay.Off( Port2 );
// Skimmer delay after feed or wc, 60 minutes
     ReefAngel.Relay.DelayedOn( Port3,60 );
    ReefAngel.Portal( "Squishie89" );
    int x,y;
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,75, "PHE:" );
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,75, ReefAngel.Params.PHExp );
    // Water Level
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,75, "WL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,75, ReefAngel.WaterLevel.GetLevel() );
    ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
Next
Return to Ask anything here
