Avast ATO and RA+
PostPosted: Fri Jun 13, 2014 8:47 am
Just to confirm, your ATO is disabled from 10pm to noon, right?
What time did you perform your test?
PostPosted: Fri Nov 21, 2014 4:55 pm
I did FINALLY figure out how to make the ATO work. However, now I cannot get my time out to work. Here is my updated code (sorry for all the notes, and the code that is //-ed out above the ATO coding is what I had before, kept it to copy it). I am wondering if the time out needs to be in the custom code in the void loop? Not sure.
  ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port8Bit;
  ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
  InternalMemory.OverheatTemp_write( 810 );
  ReefAngel.Relay.On( Port3 );
  ReefAngel.Relay.On( Port5 );
  ReefAngel.StandardLights( Port1,13,30,22,30 ); //set for actinic
  ReefAngel.SingleATO( false,Port2,900,0 ); //15 min time out
  ReefAngel.StandardLights( Port4,14,0,22,0 ); //set for white light
  //removed wavemaker functions because I don't want them turning off
  ReefAngel.StandardHeater( Port7,775,780 );
  ReefAngel.PWM.SetDaylight( PWMSlope(13,30,22,0,15,100,30,15) );
  //ReefAngel.PWM.SetActinic( PWMParabola(13,0,22,30,15,100,15) );
  // prevent auto top off from 2200 to 1200
  //if (hour()>12 && hour()<22)
  //ReefAngel.SingleATO( false,Port2,600,0 );
  //else
  //ReefAngel.Relay.Off( Port2 );
  ReefAngel.SingleATOLow( Port2 );
  // Skimmer delay after feed or wc, 30 minutes
  ReefAngel.Relay.DelayedOn( Port3,30 );
  ReefAngel.Portal( "Squishie89" );
  int x,y;
  ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
  ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
  // Salinity
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
  // pH Expansion
  ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,75, "PHE:" );
  ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,75, ReefAngel.Params.PHExp );
  // Water Level
  ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,75, "WL:" );
  ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,75, ReefAngel.WaterLevel.GetLevel() );
  ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
PostPosted: Sat Nov 22, 2014 7:22 am
Code looks ok, except for this line:
Technically, it will only run from 1 PM to 9 PM.
Run the controller test again. If you can't get it to change state, then there's an issue with the topoff unit. Since you've replaced the switch, I'd suspect the cable. Check the pins on the cable and make sure they're seated properly. If you have a voltmeter you might check continuity in the wires.
PostPosted: Sat Nov 22, 2014 12:31 pm
cosmith71 wrote:Code looks ok, except for this line:
That is supposed to be there. My tank is near my birds and they don't get woken up till noon/1pm and I don't want the top off pump bothering them while they are sleeping.
I will check the cable, thanks so much, Colin!
PostPosted: Sat Nov 22, 2014 12:50 pm
Make sure you have the correct settings in internal memory
PostPosted: Sat Nov 22, 2014 2:25 pm
I have an Avast ATO. If the ATO runs then the issue regarding timeout is not the ATO, most likely code related.
My code for the Avast uses internal memory and is every simple:
ReefAngel.SingleATOLow( Port1)
I control the timeout from the portal.
PostPosted: Sat Nov 22, 2014 2:31 pm
OK, so when I replied, I somehow missed all of page 2, and missed that you'd fixed it and moved on to another problem. :oops:
So now, it won't time out? Like Roberto said, check the internal memory setting. You can do that from the Portal.
PostPosted: Sat Nov 22, 2014 4:22 pm
It does time out, the problem is I thought I set the time out for 15 minutes, it times out in 5 min or less
PostPosted: Sat Nov 22, 2014 5:30 pm
Check in the portal under internal memory settings. You have 15 minutes specified in your code but the last iteration uses memory which we cant see how yours is set.
PostPosted: Thu Nov 27, 2014 6:09 pm
I was able to get into the internal memory settings through the portal, currently trying to get it to save.
I don't understand what in my code makes it use the internal memory, I would prefer to keep everything in the code and not use the portal.
Return to Ask anything here
